Very cool! - Cost? Care to share a bit more about the production process? - I think the design is just dandy - only thing I'd change is some 1/4 20's above the hotshot so you could mount the camera via hot shoe to the cage as well.
Very Nice Hessler Lots of 1/4 20 mounting options. It will give your camera some good weight that you will find a bonus. I put a rubber gasket on the bottom plate of my cages, plus added a small block to the right back side of the bottom plate to help secure the camera in the cage without having to torque the camera base screw down to much or over tightening it too keep it from moving when using a follow focus.
