Well, they found another way for it not to compete with the GH4... artificially limit the recording time for the U.S. model too.
@Doctor... no, it's a stripped down GH4 in a less sturdy, smaller plastic body.
- Maximum time to record motion pictures continuously with [MP4] in [4K] is 29 minutes 59 seconds.
 - You can continuously record a motion picture with its size set to [4K] in [MP4] or [4K PHOTO] without a pause even if the motion picture exceeds 4GB. However, the recorded content has to be played back as multiple files.
 - Maximum time to record motion pictures continuously with [MP4] in [FHD] [HD] [VGA] is 29 minutes 59 seconds or up to 4 GB.
 - Maximum time to record motion pictures continuously with [AVCHD] is 29 minutes 59 seconds in Europe.
From official specs.
@MarcioK, I don't believe the G7 has the same Sensor as the LX100. I believe they've said that it's the same sensor as the GX7 but with the Image Processing of the GH4.
The thing that shocked me was no NFC. Guess they felt it would help keep the cost down not to include it, but that seems a bit odd.
@wickitom I would assume that would be the case. Shoot in 2160p and down-convert to 1080p if you need to.
Even though the G7 is crippled, it might work for me. I don't do any long recording, don't need HDMI out. I just need good image quality, so I'm interested in the quality and type of image it produces. Will try with my favorite lenses, which reminds me, are some lenses incapable of getting full benefit of 4K due to their resolving power? I have some old 1972 Lomo lenses, so don't know how they would work with 4K camera. Great with GH2.
Was hoping for 1080p higher bitrate, GH4 is out of the question since it is $1000 more body only.
Since, the 1080p bitrate is low, would it be more beneficial to shoot only in 4k and later downscale to 1080p for better overall reproduction of less noise, better colors, and sharper?
Specs say that only AVCHD limits are region dependent (present in EU only).
MP4, MOV are global and now have 4GB limit also.
Vitaliy_Kiselev : 'With around 95% probability HDMI out won't work during recording.'
Thanks. A blunder of Panasonic.
Im not convinced that the position of those 2 rotary dials on the grip side are going to be very comfortable/accessible. Are there other cameras that have similar ergonomics for the dials? Are they easy to use?
The rear dial is indeed strange. Remembers the back dial of the Olympus EM-10 (which is amazingly good) but in a different position, and with a button on the center. Only with one in the hand could say if it is good.
The front dial: very similar of the E-M1.
Does the 30 minute limit apply to 1080p modes as well? If so then that really is a deal breaker.
Crop Factor info? Specifically 4K crop?
The output HDMI can record when are recording or is castrate as the great GX7?
Just used the FZ1000 as a b-cam to the BMPCC. The results were very good for interviews, however, color matching was not perfect. I wonder how this cam would match the FZ1000?
I think they did a good job at providing a very good enthusiast cam while still protecting the pro line. The 28mb of the G6 was already very good.
