PR
Integrating 4K video recording capability and a variety of 4K Photo functions, the LUMIX DMC-G7 combines outstanding image quality alongside a level of mobility that isn’t achievable with traditional DSLR cameras.
The LUMIX G7 is the latest realisation of Panasonic’s ongoing commitment to digital imaging innovation. The integration of a wide variety of cutting-edge digital technologies – including 4K Video and 4K Photo – allows professionals and amateur photographers alike to capture the perfect moment during any situation in stunning quality. Versatile and powerful, the LUMIX G7 brings even more control and creativity to all of your photographic experiences, from family get-togethers to capturing travels abroad.
Reimagining photography with 4K Photo
Panasonic’s LUMIX G cameras are renowned not only for their still image quality but also for their high quality video capability. The latest addition to the range builds on the successes of the LUMIX DMC-GH4, which set new standards in 4K video capture. The LUMIX DMC-G7 records stunningly smooth, high-resolution QFHD 4K video in 3840×2160 at 25p (50Hz) or 24p in MP4 in addition to full-HD 1,920 x 1,080 at 50p (50 Hz) videos in AVCHD Progressive or MP4 (MPEG-4 / H.264) format with practical full-time AF.
Utilising the LUMIX DMC-G7’s exceptional 4K performance, Panasonic has been able to reimagine and reinvigorate the photographic process as we know it. Using the 4K video recording capability, the 4K Photo function allows you to extract with exact precision an 8-megapixel still enabling even the most fleeting moment to be caught in a still image.
Three exclusive 4K Photo functions are newly integrated into the LUMIX DMC-G7: 4K Burst Shooting, 4K Burst (Start/Stop) and 4K Pre-burst; all of which help allow you to capture and record that perfect picture by cropping the exact frame you want out of your 4K video footage.
4K Burst Shooting allows up to 29 minutes and 59 seconds of continuous shooting at 30 fps, which can be used just like a photo burst shoot mode by holding the shutter down. Similarly, the 4K Burst (Start/Stop) mode starts consecutive shooting with a single press of a shutter button and stops it with the second press, which is more suitable for shooting opportunities that require a longer waiting time. The 4K Pre-burst automatically records 30 frames the second before and after the shutter is pressed, giving you 60 chances to capture that perfect moment. Both the 4K Burst Shooting and 4K Burst (Start/Stop) modes allow you to capture almost 30 minutes of footage at one time, giving you tens of thousands of image possibilities in a range of different image ratios: 3840×2160 (16:9), 3328×2496 (4:3), 3504×2336 (3:2), 2880×2880 (1:1).
The power to capture the highest quality images
The LUMIX DMC-G7 integrates a 16-megapixel Digital Live MOS Sensor that achieves high resolution and sensitive image recording with minimum noise. The Venus Engine image processor with quad-core CPU also enables high speed signal processing at 8 fps (AFS) / 6 fps (AFC), allowing you to focus on and capture fast moving subjects with accuracy and ease.
The Venus Engine improves color reproduction with accurate evaluation of every frame, analyzing not only the color itself, but also saturation and luminosity. And the LUMIX DMC-G7 is also able to capture crisper shots than ever, even when using a small aperture, thanks to the processor’s new diffraction compensation capability.
A new and improved Multi-process Noise Reduction (NR) system applies effective noise reduction and detail processing based on the specific environment and conditions of each individual shot. Plus, the newly added Random Filter granulates chromatic noise and blends it into the image for natural looking shots that replicate exactly what you saw when pressing the shutter. Another result of this new NR technology is that the LUMIX DMC-G7 is capable of shooting up to a maximum ISO 25600.
Fast, precise focus with Panasonic’s Depth From Defocus technology
The LUMIX G Contrast AF system is incorporated into every LUMIX G camera and is capable of digital signal communication of up to 240 fps, resulting in breathtakingly quick and smooth auto focus.
The Contrast AF system in the LUMIX DMC-G7 is further enhanced by Panasonic’s integration of Depth From Defocus (DFD) technology1 which shortens the focusing time even further. DFD calculates the distance to the subject by evaluating two images with different sharpness levels while simultaneously analysing the optical characteristics of your composition. As a result, the LUMIX DMC-G7 achieves ultra-high speed AF of just 0.07 sec2. This lightning fast AF becomes increasingly beneficial as focal length increases and also enables significantly faster conventional burst shooting (8 fps AFS / 6 fps AFC) compared to its predecessor, the LUMIX DMC-G6.
Low Light AF makes it possible to set focus on the subject more precisely in extremely low-lit situations such as a moonlit walk along the beach. Furthermore, for the first time in the industry, the LUMIX DMC-G7 also integrates Starlight AF, allowing you capture individual stars and constellations in the night sky. In addition to the conventional Face Recognition AF, the LUMIX DMC-G7 also incorporates Face / Eye Detection AF, which automatically sets focus on the eye of a human face for portrait shots full of individual character. Similarly, Pinpoint AF allows you to magnify a specific target area to set precise focus point on your subject giving more control to the photographer and images that appear exactly as intended.
Versatile and mobile, wherever you are
The LUMIX DMC-G7 incorporates a newly developed high-precision, high-speed dual OLED (Organic Light-Emitting Diode) display for the Live View Finder (LVF). The resolution of the LVF display area has increased to 2,360K-dots and boasts a magnification of approx.1.4x / 0.7x (35mm camera equiv.) The rear monitor features a 3-inch 1040K-dot Free-Angle touch screen display. Both provide 100% field of view to ensure you’re not missing a better shot at the periphery of the frame.
Thanks to the newly designed large eyecup, the visibility of the LVF has been dramatically improved. Image output between the LVF and the rear monitor is also switched automatically with the eye sensor on the LVF, in order to conserve battery. The new adoption of OLED not only improves resolution, it also provides high speed response with minimum time lag, allowing you take capture the exact shot you wanted.
To further enhance user control, the LUMIX DMC-G7 is the first LUMIX G Series camera to feature a new drive mode dial in addition to traditional front/rear dials. The drive mode dial enables activating modes such as 4K Photo more efficiently, allowing you to frame and capture photos and video faster and more accurately. As always, you can change settings such as aperture and shutter speeds with the front/rear dials and also temporarily change the assignment of specific settings using the Dial Operation Switch.
Easy Wireless Connectivity via Wi-Fi with Smartphones
The LUMIX DMC-G7 integrates Wi-Fi connectivity for a flexible shooting experience and fast and easy image sharing. It is easy to connect the camera to a smartphone or tablet, allowing you to post images and clips to social media or email them to friends and family almost as soon as they’ve been recorded. Alternatively you can use your mobile device as a remote control for the LUMIX DMC-G7, changing settings such as focus, aperture, shutter speed and ISO, before triggering the shutter release.
- New UHS-II SDXC Memory Card Compliance
 - New Max.1/16000 sec High Shutter Speed
 - Improved Creative Panorama (360-degree)
 - 3.5mm Microphone Socket
 - Focus Peaking
 - Silent Mode
 - Level Gauge
 - WB (White Balance) Bracket
 - Creative Control with 22 Filters
 - Time Lapse Shot / Stop Motion Animation
 - P/A/S/M mode for Video Recording
 - iA+ (Intelligent Auto) Mode for Photo and Video
 - Scene Guide with 20 Sample Situations
Hands-ons
No headphone output, SD card in battery compartment
Though we handled a prototype, something about the camera felt off. The GH4 feels great in the hands, but the G7 just didn’t sit will in my paws. The grip feels a bit weirdly angled and the rear dial on top of the camera also feels a bit out of place.
http://www.thephoblographer.com/2015/05/18/first-impressions-panasonic-g7/
Camera seems to be region locked (PAL/NTSC) and also has hard set 30min limit in all regions.
This is preliminary data.
Well.... double gosh darn for me :-/ Guess that rules it out as a viable option for me :-( That is two strikes against it already! Not going to consider it as an A cam at all (well, maybe after it drops down to $400ish on sale in a year or two then I might maybe pick it up as an extra C cam for multi camera wedding shoots)
You always have second chance to fix errors... and make them again. (c) Panasonic management.
Panasonic motto.
indeed 30 min limit is a deal breaker for me, why I'm still on the G3
are the hacks for G6 etc still happening or it got too boring?
this G7 sounds like a prime candidate with the time limit and the 1080p bitrate etc
For me it's still going to be a very welcome option. The G7 is a major upgrade for me over my GH1 and G5's. I still have my GH1 for long recording times if I need it. I would use the G7 as an A cam for much of what I do. I feel like i've gotten beyond great value for the low price i've paid for my Panasonic Cameras. None of which I paid over $300 for.
I did see that at 4k it is 100mbs, what is it at 1080p?
Top post. It is from 17Mbit up to 28Mbit (as I understand later is for 50p and 60p only).
Extremely ironic they've got a video about "Family without borders" yet the camera can't switch between PAL and NTSC!!! Arrrgghhh
@aria , yup I started with a GH1 and just purchased a second GH1 for weddings so I have that unlimited recording length.
@renovatio , wouldn't get a G7 for slow motion anyway, doesn't have 96fps
I think they did a good job at providing a very good enthusiast cam while still protecting the pro line. The 28mb of the G6 was already very good.
Just used the FZ1000 as a b-cam to the BMPCC. The results were very good for interviews, however, color matching was not perfect. I wonder how this cam would match the FZ1000?
The output HDMI can record when are recording or is castrate as the great GX7?
