  • 3230 Replies sorted by
  • Here are a couple of DCI 4k files I was using to test some settings and some sd cards performances. Most clips shot at contrasty time of day, around 12 noon, and I was a few feet from neighbor's central heating unit. I apologize for the clips being "trees and leaves" footage.
    https://www.dropbox.com/s/o3iqbascz5k97sx/P1120588.MOV?dl=0
    https://www.dropbox.com/s/g6oc2z1nxpxh21m/P1120775.MOV?dl=0
    https://www.dropbox.com/s/mst0nbc186qta0u/P1120776.MOV?dl=0
    https://www.dropbox.com/s/3hld7grv9gvfily/P1120779.MOV?dl=0
    https://www.dropbox.com/s/n204mwligy0p35r/P1120791.MOV?dl=0
    https://www.dropbox.com/s/sxq5rojm2ccxvg3/P1120795.MOV?dl=0
    https://www.dropbox.com/s/rmoespk8f21hvjr/P1120798.MOV?dl=0
    CLICK THE THREE DOTS TO THE RIGHT OF THE DELETE TO DOWNLOAD FILE. Let me know if the download method is different for you.
  • @natureflixs @bleach551
    Thank you for your clips! If someone has other clips for downloading (at 4096 × 2160 and with a very flat profile) or knows where to find them, let me know, I'd like to test also some color grading and converting from 4k to 1080p.
  • Quick 4096x2160 video with flat profile ( CINED, Contrast, sharpness, NR all -5) : https://1fichier.com/?bwotyq7gh0
    12-35mm Lens @12mm-F2.8
  • @yaz72
    It says "file not found"
  • a video made in the autumn. using the 4k for the landscape and 96fps for the ducks...
    footage out of cam
  • Hello people. Anyone have had problems with a broken microHDMI port under warranty? Our GH4 microHDMI port broke (after very little use) and we sent them to assistance for repair. The GH4 is new and under warranty, but they are asking 200 euros to repair the sucker. We are in Italy. I'd like to understand if this common practice of Panasonic warranties or just an Italian habit. Thank you!
  • flablo you should post this elsewhere or start a new topic, I think it will get lost here.
    Anyway, sounds like the old "impact damage" scam that Nikon El Segundo pulled on me and others. I would contact Panasonic about this.
  • Definitive test:
  • First proper test :-) Just remove blur.
  • @flablo mine broke. I am in Panama so the idea of sending it in fills me with dread, I ended up buying another one and a cage to be more careful, still thinking of getting mine fixed. It's a stupid port but I assume it was broken due to my use, not faulty from the factory, which is what the warranty covers as far as I know.
  • I have 2 questions / settings I wanted to change. How do you get the GH4 to adjust ISO with the top dial? I've been trying to figure it out, but the ISO can only be changed with the rear dial. And also, was there a way to remove the direct focus area box (white box in the middle of the screen which you can touch/drag on the touch screen to focus) ? It goes away when changing to autofocus, but is there a way when switched to manual focus?
  • @Panamedia For the rotary dial re-assignment, check P312 of your manual for Dial Set.
  • Changing the dial settings only effects the shutter/aperture and not your ISO. I looked a little more into it, and reset the settings on my GH4 and it is able to adjust the ISO with both the dials now, but I still am not sure what setting it was before that caused it not to work. The thing I noticed that was different and is probably the reason was that in "M" mode, there was an "ISO LIMIT" setting that appeared when adjusting the ISO, which was controlled with the top dial. When changing into movie mode, there is no ISO LIMIT thing there at all, and you can't adjust ISO with the top dial. Not sure how to bring back that ISO LIMIT setting though.
    I thought that it might be appearing due to the ISO Limit Set in the Rec menu, but that doesn't do anything.
  • First try with the GH4
    Was a demanding shoot with lots of lighting changes. Couldn't keep up with correct white balances so was impressed how much I could do in post to match up the shots. Not perfect but that's more to do with my abilities than the cameras! The footage at the end is from the Red Epic.
  • Quick 4K UHD AF test of the GH4 with Leica DG Nocticron 42.5mm f/1.2 @ F1.2
  • Ciné D -4-5-0-5 0-255 pedestal +5
  • Wow. I suppose that cinematographer, (Fery), could make any camera look good, but...wow. Makes me think "Who needs anything more than a GH4?". But, I will still hold out for the next generation camera that can give us 4K at 60fps. Probably need a new computer to edit such data files, but...
    I will be renting a GH4 for my daughter's season ending Championship Swim meet in about a month. I probably won't want to send it back and return to using my old GH3. :-)
  • jjj_ri_usa
    Two things you may also want to rent/buy 1. Polarizer (not always needed) 2. 35-100 lens
    Be sure to keep the shutter speed up enough for the action. I recently shot 4k at 120s and was surprised how good it looked.
    I am getting a 4k 60P HC-X1000 next week and let you know how that compares to my GH4. If it has the same low light problems that the HC-W850 did, it will will be returned too. The problem is the gap between good light and no light. The W850 was good down to about 800 ISO and then in dark the IR would kick in. Where I record, I doubt lights would be allowed but I will try a LED anyway.
  • @RRRoger. Thanks for the recommendations. I have the 35-100. I didn't use a polarizer last year with my GH3, and since the swimmers mostly stay on top of the water, I think I'm OK without one. But...in addition to renting the GH4, I've started to think about other expenses. I don't have a 4k monitor. In fact, my graphics card won't support 4k, (I have an old NVida GTX 470). So, with the meet about a month away, I'm having a few second thoughts on renting the GH4. I have to do some pricing of new video cards and a 4k monitor. So...it might not happen for this year's championship meet. Thanks again for the advice.
  • I don't have a 4K monitor, and I'm running a GTS450. 4K from my GH4 plays and edits just fine in Adobe CC.
  • jjj_ri_usa
    You might actually get your best Swim Videos by shooting at 1080p60. I had a GH3 and actually got the GH4 for Action Stills. Since then I have found the camera is an improvement in every other way as well.
    When I do take 4k Video, I drop the files on a 1080 timeline in CyberLink PowerDirector 13 to burn a BlueRay Disc or I just watch them with free VLC Media Player where I can speed up or slow down the action with a click of the keyboard.
  • @Manu4Vendetta Thanks. That's great news!
  • @aldolega and @RRroger. Thanks for the advice. Glad to know I don't need a 4K monitor to edit 4k. I shoot 95% of my clips on the GH3 using 1080/60, so that I can always do smooth slow motion by interpreting clips as 24p in PP. I'm wondering how bad 4k 24p video would look shot at a higher shutter speeds to freeze action in each frame (like maybe 1/200th). I usually always shoot at SS=1/125 when I shoot 60p. I know I should use 1/50 or 1/60 when shooting 24p, but, then the 4K stills would be very blurry. I guess I can test out how bad 24p looks with a shutter speed of 1/200 right on my GH3...
