Hi everybody and anamorphic lovers ! Here is my 2nd movie with SLR Magic anamorphot 1.33X - 50 anamorphic lens on OM-D & Sony A7 ! And now some of the shot taken with the Speed Booster copy, the Turbo Lens M4/3 to Nikon, and some comparaison between SLR Magic diopters 0.33X and 1.33X and Tokina 0.5X !
Hi everybody and anamorphic lovers ! Here is my 1st movie with the upcoming SLR Magic anamorphot 1.33X - 50 anamorphic lens on OM-D & Sony A7 !!! :)
What is happening. Will be shooting a Children movie this summer and Anamorphic would suit it perfect. But is there any chance of finding an working anamorphic adaptor?
DSO also has an option for custom iris inserts on the FF58. Hopefully they'll have a wider lens in their catalog this year.
Yeah that's pretty much it. My friends are going to laser-cut some pieces out of plastic for me, so it'll be a bit easier.
It worked well... but I need to get the final anamorphot before I can post footage that really shows it. So soon I think.
Hello Kholi can you please send some samples of your device and the result?
I made one with an x_acto knife and a lot of thick paper. Haha. I have some friends that are going to cut some apertures and 1.5x, 2.0x ovals.
It works though, and works really well. It even helps with the distorted fall off.
@kholi, may I ask which Oval Bokeh insert you were using? I'm glad you posted this cuz I wasn't sure that it would actually work when used behind an Anamorphic Adapter. This just opens up even more options :)
I should add that it's not the exact same look as a 2X, but it is better than cropping, to me. That's my POV and of course everyone's entitled to their own!
It's more so that people want to get the anamorphic traits without having to shoot up close just to throw backgrounds out. A diopter just lets you shoot closer to subject, 2X would give you the anamorphic traits if anything at all's out of focus (for the most part).
I'll go ahead and say this, and hopefully not cause any issues... when the adapter and Andrew came my way for that afternoon I had already been shooting with an Oval Insert within the Kipon adapter. So when the Anamorphic adapter went on, I had Oval Bokeh (not perfect, but close). He was aware that I had it in, and I tested with it in and out.
When applying that "creative" outlook, and with the Sigma 18-35, it was enough for me to say hell yes. But, I'm also not above trying things out, some people will be.
I don't view it any differently than adding a speedbooster to get a wider field of view, or using clamps to try and cobble together some other anamorphic. I would rather have someone dye-cut or laser cut a set of various apertures and anamorphic bokeh, use those in the Kipon adapter or another adapter, than have to fiddle with clamps.
So, again, I did this on my own and I know that it works and works well... others mileage may vary, as someone that actually shoots with larger, anamorphic primes, I think this is a really good alternative with or without the oval bokeh insert.
That's why I'm getting one.
Were you able to get any good oval bokeh stuff when you tested it? Using that diopter Andrew had really helped and I know they were making a much better one than the one we used. It was just to show what the lens could do. Really wish I would of had a day to play with it and get the focusing down. I'm sure it's easy once you know what to do but we were pressed since we had a meeting as well.
In my case I actually don't need any adapters... I have a set of anamorphics that I use when I really want to shoot.
The bigger deal is having run and gun, because the Kowas need a Mattebox and with a mattebox comes filters etc. I literally want to just use my Hoya ProNDs, a lends hood, and a zoom -- go and shoot.
So I agree with @Aria as well, and that's a big reason why I want to the SLR.
@aria has some strong good points about its flexibility.
Meh! Looks good to me and especially the fact that it is so sharp and clean. It allows me to choose to get whatever look I want with different taking lenses and post treatment. i'm not that fond of an anamorphic adapter that has so much "character" that it's no longer flexible. This adapter kind of stays out of the way a bit, which can be a plus. It gives just enough of the things you want in an anamorphic, but not over done so that you end up limited in it's use cuz it always looks the same. I see it as an advantage.
no one has ever mention anything about apples vs oranges. For me, only me, its too well made that it lacks character.
What??
yes, character is about the way you behave, and this little bastard has 1 year old and behaves like it was 30. Too sharp for me. About the oval bokeh its also a personal taste how it behaves me don't like. Why? wont say cos it will bring flame to the already damaged thread.
I'm with @vicharris on this one. Expecting to get 10's of thousands of dollars worth of performance in a sub $1000 adapter isn't rational.
However, this is one shot that sticks out in my head as a definitive Anamorphic "Oval bokeh" shot. I bet if a similar set-up was used with the adapter, it could get comparable bokeh.
Yep, it's a G series lens.
As for the oval stuff, I shot some other stuff that was really oval and a lot more of it but because Andrew wasn't over my shoulder, holding my hand, I kind of screwed up the focusing a bit. No need to show stuff like that on forums. I get some of the stretching and other characteristics people are looking for but at some point, there has to be an understanding of what will be expected from something like this.
The "It doesn't look as good as Bladerunner" type comments are just insane in my mind.
It should be one of a car interior.
Raindrops/bokeh's Oval from the 2x stretch. I'm pretty confident that's a Panaovision lens, just by the twisted frame.
I thin kit's mostly that they are comparing anamorphic looks, because you can get similar to that Panavision with cheaper adapters (I saw a 2x one go recently, Lomo Foton-A... 3,000 though!). Before I used the SLR "briefly" i considered that 1.33x was not enough.
With some adjusting and creativity I do think it can get there?
Is that the right frame @kholi? Am I supposed to look at the raindrops on the back of the windshield? I've seen the other grab you've posted from this movie and what lenses were used on this movie?
I guess I'm just tired of hearing people bitch about a cheap lens and compare it to $50,000 pieces of glass.
He wants to see this:
http://www.apnatimepass.com/killing-them-softly-movie-photo-24.jpg
Please show us then, this oval bokeh
I just googled it and every image that came up, even from some panavision labeled stuff looks like that.
I know what you mean about the overall look. The adapter may not be for everyone. I sent you a message.
That bokeh is not that oval. I dont wanna be the bad guy here. Only advantage i see here is the real aspect ratio. That being said, im not impresed by its character. Yes its Sharp, but too clinical, even its lfares are too perfect lols.
