I just finished this video. Shot mostly with D5200, some GH1 and RX100
@mojo43 Where can I find this hack??
Good news there is a video bitrate hack for the D5200 camera
Glad to hear that AF-ON problem was driving me nuts!
New firmware
https://nikoneurope-en.custhelp.com/app/answers/detail/a_id/59153
Sharpness test GH3 and Nikon5200. Frames and charts are from:
http://video-dslr.slashcam.de/
I put charts together in same picture and sharpened frames.
I do the same, but don't use the profiles. To me, I just get as close to what I want it to look like in camera. For example the last one that I shot I wanted an red/orange tint throughout. I knew this in advance... Play around with both. You have a lot of fun stuff ahead of you!
Well, yes, i'd like to shoot some shorts and do color grading with after effect..
The flat profiles are lifting areas that may show noise, but are normally hidden. I think that the profiles are probably only of use if you want to do some serious colour grading.
Would like to get as much DR i can, but i don't want noise. So, do you suggest to don't load flaat profile in camera?
Other settings are you experimenting? A definitive set do you like to use for every situation? Thanks a lot. Taken d5200!
New firmware is available
https://nikoneurope-en.custhelp.com/app/answers/detail/a_id/58934
Do you guys use the histogram for video shooting? What histogram situation is best expected for flaat profiles? I notice pattern noise in the far left zone of the histogram and avoid shooting low key. The display is very accurate on the camera, but I always try few test shots before shooting and decide what setting I need.
Anyone can share their experience?
Impressive low light results.
Hi, can someone tell me hot to load this faat 11 profile? Is it valide on its own, nothing else we need, some other in-camera settings suggest? Thanks a lot I'm thinking to get this nikon d5200 as a less expensive option than the others, also: which cheap lens do you suggest? One doitall.
Thanks
Hi all,
Is there some way to reset the camera shutter count?
Thanks
I will try it. Thanks
@paglez Try shooting in standard with the contrast down and get the exposure right in camera. I have seen the noise before, but it typically only happens when I am not getting the exposure right in camera.
I'm using kit lens (18-55). Flaat 11 style. I get a very noticeable linear pattern noise, specially in low light shots.
@paglez Thanks! I shot Standard with contrast bumped down 2 notches and sharpening at 2. I shot with a Sigma 30mm F1.4 and and some of the slow mo was done with the Sony Rx100.
How come you are having trouble? What lenses are you using?
@mojo43 Very good video. What lenses did you used? What Profile? (Flaat,portrait, landscape) I have a Nikon 5200 and I'm not able to get these great pictures!!!
I have been shooting with the D5200 since the summer and I absolutely love the video quality... Here is something I shot. Let me know if you have any questions or comments!
http://rungunshoot.com/nikon-d5200-studio-and-documentary-footage/
Check Brandon's vimeo channel for the test he made using the D5200.
Music video shoot with Nikon D5200 and Flaat 11 slight collor correct
