@apriori yes, this is one reason that I'm very keen on the MK2. The ability to keep the signal digital from mixer to recorder is awesome.
Just got delivery of my Tascam DR100 mkII yesterday. Played with it a little. Need to get to know it very soon as I will be using it on 2 shoots latter in the week along with a rented Sound Devices 744T. Will report back after the week end. So far the only down side is it eats up AA batteries with phantom power on (Duracel alkaline). About 10 min of recording time on just the AAs. Not an official test though. Hadn't charged the rechargeable so don't know about that one yet.
Make sure that you use NiMH batteries. Alkaline are useless for pro gear as they contain next to no power. I have used the MKII for over an hour with power to spare off 2500mah NiMH. They are also VERY cheap!
Great to have the built in backup power available!
So power up!
I have the old DR100, does the Mark II record a hotter signal? I've always got my level dials way high for dialog, presumably this is because of DR100 music roots.
@brianluce, Don't have the Mk1- so can't tell... but the level is nice and hot...
Review comparing Zoom H4n with DR-100 mk2: http://www.pauljoy.com/gear/camera-accessories/tascam-dr-100mkii-vs-zoom-h4n-review/ Reviewer tested with Sennheisser MKH416 shotgun mic, and I'm a little suprised that he didn't comment on differences in pre-amps, but I've asked and hopefully he will respond on the issue.
I've concidered the DR-100 mkII a lot, but start to think the Olympus LS-100 is a better choice for me. It's a little more expensive, but: - from what I understand it might have an edge on the preamps/noise levels, but I'm really on thin ice trying to compare results from eg. http://www.avisoft.com/recordertests.htm - LS-100 battery capacity is stated to 12,5 hours (according to Olympus. And I expect that to drop markebly when using phantom power, which I need). The DR-100 mkII using built in mic will record 5 hours with Li-Ion battery + 4 hours AA NiMh batteries (accordring to Tascam). I guess it's a close call, but I actually prefer buying an extra Olympus battery, and forget about the battery fuss on set.
I haven't found many reviews on the LS-100 yet, only a german preview: http://www.audiotranskription.de/olympus-ls-100 Lastly, ofcourse the Roland R-26 is still a good candidate. I like the ergonomics, but I find it a little too big.
The LS-100 looks the first serious candidate for challenging the low self noise and quality of the Sony PCM-D50 as a portable recorder AND which also has built in XLR inputs. It also appears to have more dynamic range than the Sony. I love my Sony, so much so that I even converted a Denecke PS-2 as an XLR phantom power to work exclusively with it. The quality is almost on par with an Sound Devices 302 mixer. Still it means carrying two units in a very small Thinktank pouch rather than one, and that is where the Olympus has a real opportunity to clean up. I would say that it is no contest compared to the Tascam.
update: Having listened to the german preview, unfortunately he concludeds (and I agree) that it still falls short of the Sony. If you listen to the tracks at the end there definitely is a rumble which needs a low pass cut and there is some serious susceptibility to wind noise. I would say that the search for a small all-in one portable recorder which can contend with mixer/recorders still continues. It is true that the Marantz continue to be the only other player that can approach the Sony.
You can look at DR-100 MK II review make by Ken, it has various measurements
Like all these little portable audio recorders, performance is only at a 15- or 16-bit level even if set to "24 bits." Even though 24 bits wiggle, the bottom 8 bits are just noise; "24 bit" is a sales feature and not related to actual quality. There is no measurable or audible improvement in the 24-bit mode
This is a sad sad day that Ken is now reviewing audio devices, (albeit for DSLR's... don't know why- wasn't he anti DSLR at one point??)
As for 24 vs 16 - describing the bottom 8 bits as 'just noise' is a bit of a joke. As you would know @VK it doesn't really work that way...
The review mentioned by evero few posts above claims that
 ...the DR-100 mkII drifted out of sync with recordings on my cameras slightly on very long shots. With both recorders running side by side with my Sony EX1 for an hour the audio from the H4n would sync up correctly whereas the audio from the Dr-100 was 4 frames too long towards the end.
Can anyone of DR-100 MKII owners confirm that?
I've got the ZoomH4n. Pretty decent mics, decent mic preamps (a GOOD preamp is another thing, and cannot share the case with something else!! and I've got one) but what I like most is WIRED REMOTE! If one, the problem of all these tools is WIND. I've got a custom deadcat-sac that covers it all. Remote is the killer solution. I can record the field noise, have a sennheiser me66 on the boom AND a mono wireless tie lavallier. 4 tracks in one 250 eur machine. I'll not upgrade it soon, it is still too good to be true! :-D However, till now nothing compares to the sound I heard from the Sony stuff, that are priced double.
What is this doing in Tascam topic?
very interesting read:
Audio Recorder Roundup: Zoom H4n vs. Tascam DR-100mkII vs Tascam DR-40
http://nofilmschool.com/2012/04/audio-recorder-roundup-h4n-zoom-vs-tascam/#more-21070
I recently purchased a Tascam Dr-100 Mkii to replace my Zoom H4 (original, not the H4N). The problem is, it seems I have to turn the mic gain on high for the XLR inputs otherwise I can't hear anything. The resulting recordings have a very audible hiss in the background. Is this normal? Am I doing this wrong? Do I have a defective unit?
At this point, it sounds to me like the Zoom H4 has noticeably better sound. That's because on the Zoom, I only have to set the mic gain on low to get sound levels.
I did a mic comparison test with a Seinheisser k6 ran via xlr straight into the recorders. I'm a sound novice so it's not the most controlled setup. I just recorded sample wav files at 48Khz 16-bit and tried to keep audio around -15 db:
Am I crazy or is there way more hiss in the Tascam file? I had the Zoom at Low Mic Gain but levels were cranked to the max (127). The Tascam was on high mic gain but the levels were only at 3.
@mattman is the gain setting on the BACK of the unit set to "High"?
@brianluce yes on the Dr-100 it is. On the Zoom, it's set to Low. If I don't have the Dr-100 on high, I can barely hear anything.
And phantom is on, etc?
@Vitaliy_Kiselev no phantom isn't on. The seinnheisser's running off a AA battery.
Try to run it from phantom power, if possible.
As output can be just very low.
currently playing with a marantz 620 mkii -- no 48v phantom power or XLR but here's a few things that are hot:
1) Onboard stereo mics are just beautiful. So Rich. 2) Does 5v phantom to a pin mic, so for crucial interviews, you can wire it up and get lectrosonics+ sound for 1/10 of the price (its about the size of a deck of cards) 3) If you got a mix-pre D (which I highly recommend) then you can just use this as a recorder -- no need for xlr in this case
Gonna try it with the senny mke 600 tomorrow.... doing solo shoot in the jungle in Feb and I've gotta strip back as much as I can so hoping it'll be a good combo.
BTW, I'd strongly recommend against the DR-40 -- I had it, and the headphone jack stopped working mid-interview on me (with a fairly senior person in the US army). Most embarrassing moment of my life as I tried to fix it, realized it was bust, and then forged ahead, hoping that it was in fact recording even though I could hear no audio.
Hence trying the marantz. Know a lot of radio reporters in US and Canada who use it so curious. 661 mkii also looks pretty shit hot.
Camera equipment you will have to buy every couple of years, but unless you abuse it, sound equipment you will not so learn from my mistake and buy the best thing you can afford. My DR-40 was $200 down the drain....Maybe there is something better out there but in my experience you can't get clean phantom power unless you have a mixer.
and I'm wondering if the preamps worth investing in a 500$ shotgun mic, for picking up outdoor sounds for sampling (birds, cars, animals, nature).
It all depends on specific mike. Best is to use good and hot mike with DR100. DR100 preamps quickly degrade with gain increase.
I'm looking at buying a DR100 mk2, and I have a few questions. If I set the recorder up so it feeds an audio signal into my GH2-- resulting in a stereo track synched to the video-- will it also record its own audio tracks on an internal SDHC card?
Are there issues with syncing long takes (does the audio go out of sync after an hour or so)? And how do you resolve this problem if it happens?
And finally-- if I got a 4-track Tascam DR-60D instead, what are the pluses and minuses? Is losing portability that important? Is having four tracks really that much of an advantage?
You can record while passing the signal through.
Any two devices with independent clocks and no time code are subject to drift.
In what way is the DR-60D not portable?
Fran
I own both the DR100 II and DR-60D, and I've ended up using the 60D exclusively thanks to its form factor, ergonomics and more channels+features. The only thing missing when compared to the DR-100 is obviously its mics (which I never used anyway) and its rigidity, the 60D is flimsy and feels cheap (bendable thin plastic everywhere), but on the other hand it's super light. In TV productions, if we need simple mobile sound I'll usually give the DR-100II, simply because of its better construction, and sound people are also familiar with it.
