Official Final Cut X topic, moving to ARM and vlogging
  • 405 Replies sorted by
  • I came across a post from Alex4D suggesting imovie2013 & FCPX10.1 share the same software/code which gives some insight in what we can expect in the new release: http://alex4d.com/notes/item/imovie-2013-is-consumer-ui-on-fcpx
  • Really? What camera and what shutter speed did you shoot at?
  • When conforming a 50p video in Final cut pro X (10.0.8) to 23,976 in a 23,976 sequence for nice slow motion, FCPX doubles a frame every second!
  • Well that would be pretty awesome since it's already so fucking good.
  • My feeling is to temper high expectations. Expect one major new feature, a couple of minor features, and lots of bug fixes.
  • The forums I've been on are expecting major, but not another complete overhaul. It's the 1.0 release, and Mavericks and the new MacPro are coming, too. Of course none of us really know, but I'd go with optimism at this point that we'll see a release to further bring FCPX into it's own. (Like 0.6 I believe it was.)
  • So the rumor mill on Twitter is suggesting there's a major FCPX update coming this week that will be a total rewrite from the ground up. Does anyone know if there have been more substantial reports of this anywhere? I can just imagine the protests if Apple decides to do another complete overhaul with zero input from the users, especially those who have adopted FCPX rather than jump ship for another NLE.
  • @B3Guy Not great at the moment using just FCPXML. However, if you use X2Pro to make an AAF, it's close to perfect. X2Pro has one li'l bug right now regarding subroles and multiclips (you have to send all clip components out to the AAF even if they are turned off in the timeline). X2Pro works fine with regular clips or synchronized clips.
    With X2Pro and subroles, I was able to turn the unorganized file below... into the organized one.
    1024 x 914 - 488K
    1024 x 725 - 372K
  • How is integration with Logic X?
  • Just wrote a "little" blog post about a workaround for dealing with multi-channel audio and subroles in FCP X. http://www.garbershop.com/?p=391
  • FCPX 10.0.9 update is now available.
    Nothing major. A few stability changes, and bug fixes.
    o Addresses green artifacts with Sony XAVC media
    o Some interlaced or retimed media could cause exports to fail
    o Includes stability improvements
  • @ahbleza @Conundrum Thanks! Glad you enjoyed it.
  • @5thwall Two days to edit a 10 minute piece... luxury! :-) Very nicely written article, thanks!
  • @5thwall,
    Excellent article!!! So many great tips and methods. I've just started finding the courage to use FCPX on pro projects and am beginning to see the potential of roles and compounding. As I change my perspective I'm starting to feel more comfortable with the new paradigm. Thanks for a clear and informative piece!!
  • Hey y'all. I wrote an article about editing broadcast news stories in X.
    http://library.creativecow.net/garber_michael/FCPX-News-Editing/1
  • @shian agreed. i tried it for a few minutes. if the color grading was more useful, i could see some application for it. otherwise, it doesn't really save me any time.
  • I installed that ProCutX app and played with it, cuz it's free if you go through the app store on your iPad - it's alright... but not mind blowing... a lot of features don't work at all, or don't work well. The grading panel is useless. I'd have been pissed if I paid $25 for it. It's an ok companion device for X, but not what i was hoping for, which was a killer control surface.
  • @squig Now we get to be 10.0.8 crash test dummies. If it wasn't for the green frames I wouldn't risk it.
    I've just been cutting for the past couple of days on a project using the new 10.0.8, and I have to say, this version of FCPX is much less crashy than all previous versions. There were times I did something that has felt like causing a crash in the past, but it just kept on going like a champ. I see no downside to upgrading at this stage.
  • FINALLY!
  • Awesome. 10.0.8 also fixes this crash i was getting constantly: https://discussions.apple.com/message/21601080#21601080
  • UPDATED!
    Final Cut Pro X version 10.0.8
    This update improves overall stability, performance, and compatibility. Updates include:
    • Support for Sony XAVC codec up to 4K resolution
    • Option to display ProRes Log C files from ARRI ALEXA cameras with standard Rec. 709 color and contrast levels
    • Resolves an issue where some third-party effects generated green frames during render
    • Resolves performance issues that could occur with certain titles and effects
    • Time reversed clips render in the background
    • Ability to use key commands to adjust Clip Appearance settings in the timeline
    • Ability to view reel number metadata located in the timecode track of video files
    • Mono audio files in a surround project export with correct volume levels
    • Drop zones no longer reset to the first frame of video after application restart
    • Fixes a performance issue which resulted from selecting multiple ranges on a single clip
    • Fixes an issue where the Play Around function did not work properly on certain clips when viewed through external video devices
    http://www.apple.com/uk/finalcutpro/whats-new/
    http://support.apple.com/kb/HT4589
    Motion 5.0.7
    • Fixes a stability issue when splitting layers in the timeline
    • Fixes an issue where launching a plug-in with a check box could require multiple clicks
    • Fixes a stability issue with CoreMelt plug-ins
    • This update is recommended for all users of Motion. For more information visit www.apple.com/finalcutpro/motion.
    http://support.apple.com/kb/HT4591
    Compressor 4 version 4.0.7
    • Removes 1 GB file size limit for uploads to Vimeo
    • Fixes a stability issue when playing back certain MPEG-2 files
    • Fixes a stability issue in Qmaster when processing multiple jobs
    http://support.apple.com/kb/HT4590
    More Updates!
    ProApps QuickTime Codecs v1.0.2
    This update adds the following video codecs for use by QuickTime-based applications:
    • Apple Intermediate Codec
    • Apple ProRes
    • AVC-Intra
    • DVCPRO HD
    • HDV
    • XDCAM HD / EX / HD422
    • MPEG IMX
    • Uncompressed 4:2:2
    • XAVC
    This update is recommended for all users of Final Cut Pro X, Motion 5, or Compressor 4.
    http://www.macupdate.com/download/39040/ProAppsQTCodecs1.0.2.dmg
  • @CurtisMack
    FCPX runs only on OSX. I don't think I'd get another Macbook Pro. Too expensive. $2k $3k? I'd rather get a PC laptop little over $1k and upgrade from GH2 to GH5 (haha). OSX is nice, but I wouldn't miss much.
  • Apologies if this has been posted somewhere on here already, but I found these tutorials to be SUPER HELPFUL for the most part (I don't agree with him on using the global exposure adjustment for setting focus exposure) http://www.colorgradingcentral.com/final-cut-pro-x-color-grading-table-of-contents
