Yes, I'm one more with the same problem! What a pity that such a great lens has a problem like this, but I cross fingers that Pana will eventually hear and fix this with a firmware update. Apart from that, the lens is terrific. I have a hands on review in my blog, with images, if you wanna see!
http://gonzalobroto.blogspot.com/2013/10/testing-my-new-lens-personal-review-on.html
Yep, let's hope they read all this :-)
Sad to hear that, the stabilizer on the 12-35mm became really good after they revisited the firmware.
Maybe more reports on such experiences can push Panny to have a second look? After all, it took quite a few people insisting that it's not OK before the 12-35 got fixed.
Thank you, theteddy.
Sad news indeed, I bought the damn thing because of the stabilizer. Can't return it as well, only repairs and I think outcome will be the same as in your case. So, I will dedicate it to tripod-only usage then.
@danbo Had a problem with the IS as well. Tested on a tripod there is no jitter that I could see but handheld there certainly was, above and beyond me causing movement. As a comparison I shot some handheld footage with the Panny 14-42 X pancake at 42 mm with IS and it was great. The 35-100 shot at 42 mm handheld was definitely jittery. So, sent it back to Japan ( I was living in NZ at the time $70 for the postage ) with a full explanation. The retailer passed it on to Panasonic who gave it a clean bill of health, but I knew bloody well it wasn't right, and insisted that the retailer take another look at it. They said that they gave it to a camera repairman who also checked it and thought it was okay. I got them to email me the report which took them a few days, which was strange since in our other discussions on the net the replys were pretty much instantaneous. It was in Japanese of course and very light on detail. ( I got it interpreted ) At that point I decided to get it sent back and bite the bullet. I'm resigned to it being a tripod only lens, which realistically for me will always be the case. So my take on this exercise is that if I'm buying an expensive item buy it from a "no questions asked if not satisfied" retailer. Hope you can get a happier ending mate.
Does anyone have annoying jitter with this lens? This parkinson-like jitter is especially visible when shooting ETC, the footage becomes unusable. I tested it alongside with my 100-300 and the problem wasn't there with the latter. I guess it's a problem with stabilizer but I would like to know if someone also have it.
This lens exhibits mesmerizing sharpness, wonderful bokeh, excellent colors, great stabilization, and a build quality that will be able to keep up with your rough and tumble life despite the plastic exterior.
It’s totally worth it for anyone that needs to shoot long.
http://www.thephoblographer.com/2013/07/07/review-panasonic-35-100mm-f2-8-micro-four-thirds/
DXOMark Panasonic Lumix G Vario 35-100mm f2.8 Power O.I.S review
Some birding:
The last shot is something else...@toxotis70 Sorry, I wrote it down wrong, but was referring to the 14-42. http://m43photo.blogspot.no/2012/09/lumix-x-pz-14-42mm-f35-56.html
there is no 12-42 lens... only 14-42 or 14-45 Panasonic kit lenses. 14-45 is a very nice lens, but no so fast.
Totally depends on what you are shooting. For me, the 12-35 would be the correct choice. I have both, I store the GH3 in my bag with the 35-100 mounted, but I switch to the 12-35 when I run and gun or for anything indoor. When I get cranking on doing timelapses (and birding) - shots I need a tripod for - then I will be using the 35-100 more.
Do you wonder which kit to choose? If you're not limited to the kit lenses, maybe you should consider the 12-42 instead? Somewhat longer range than the 12-35, has power-zoom, almost as compact as a pancake, and cheaper. But you loose some light though...
I own the 35-100; the 12-35mm f2.8 version seem to have some problems (search the net or forums here), but it would be better range (for me), anything beyond 50mm for video is pretty hard to control. Best is to find out what range you use and like the most.
Hey Guys,
if you could only own one lens for your GH2 or GH3, would you get the Lumix 35-100mm f2.8 or the Lumix 12-35mm f2.8?
And Why?
Thanks!!
I shouldn't have read this thread.
I will now have to get this lens.
Excellent test at wlcastleman, thanks @igorek7
This lens is very welcome quality upgrade among Panasonic's zoom lenses. It has improved optical and build quality, it is fast and so small compared to the equivalent FF lenses 70-200mm. I really like this one.
A few more reviews of Panasonic Lumix GX Vario 35-100mm f/2.8 Lens:
Usually Lumix kit lens works great with kit body.
Gf1 20mm 1.7, Gh2 14-140mm, Gf3 14mm 2.5, Gx1 14-42mm X, Gh3 35-100mm.
Updating my lens now.
I am not sure if it is any faster now. However, it definitely is what I would call snap focus. This GH3 really is a great camera with the 35-100mm F2.8 on it.
Lens firmware update is now available
http://panasonic.jp/support/global/cs/dsc/download/fts/index.html
On center the 14-140mm is actually just about the same sharpness wide open as it is 1 stop down. Remember you can't possibly hope to distinguish between a few lines of resolution better performance. Check out the test results here.
http://forums.dpreview.com/reviews/panasonicdmcgh1/page17.asp
I'm sure there's sample variation. But I wouldn't be surprised if that's true. 14-140 is sharper at one stop down to f/8 toward the tele end. At max aperture, 14-42 14-45 14-140 have better performance toward the wider end. I'm mostly interested in center sharpess at the tele end.
I respect the lensrental evaluation. However, I think the results are a little overstated. Sure the lens is sharper at 35mm than 100mm. However, aren't all zoom lenses like that?
From the testing I did today I had no problems with sharpness at 100m and F2.8. I would say it is amazing sharp at 35mm and extremely sharp at 100mm. Both are good things. Sometimes we get caught up in numbers and forget to check exactly what those numbers really mean.
I will post some sample images and videos that show how good this lens really is across the entire range.
I hope you guys like BMX Freestyle. The pics and videos I got at the bike park today will be really fun if you do.
