Hi everyone,
I recently flashed Drewnet v6 to my GH2. I realized recently that my burst mode is no longer working. I turn the dial for burst mode and my camera doesn't do anything. When I press the shutter button, there is no burst, it just takes a normal picture. Is my GH2's burst mode dial broken or am I missing something?
Thanks in advance.
Thanks, sw_ja. I've tried resetting using the "Reset" feature and flashing an unchanged firmware, but that did nothing. Is there anything else I can try?
I had that happen to me once. Not sure how it happened. After I reset the camera to factory settings, everything worked again.
I tried to take some burst shots with the camera pointed straight at a light, overexposed, and still nothing. I think my burst mode dial thing is busted. Is there some way to test it?
are you taking photos without enough light? I had this issue, I think it automatically disables it if there isn't enough light....I think...it happened a long time ago and worked fine when I used it the proper lighting from that point on.
