Reference again, I myself have not checked completely yet. However, @flaschus said that it is very flexible with grading. Since priority was given to my making it stabilized about this Flat4 version, using a matrix as it is, about image quality, I myself am not sure, either. Please try it! :-)
@peternap Many thanks for report mate! :-) Please tell me the comment about 720p of C1.4. Which is the more nearly better between C1.3 and C1.4?
And, since 720p of C1.5 is an entire different setting, I would like to also hear the comment about it.
I did quick comparison of C1.4 and C1.5 of TYPE-ZERO2 in my room.
*These are only in HBR30p and 720p/60.
As long as I looked at these results, I think that C1.5 is better. Although the result may change according to conditions, of course...
I also set quick comparison of GOLGOP3-13, GOP3ZILLA and Valkyrie Flat4 moreover.
Woops! C1.5 froze during the torture test in HBR30p. :-( I will improve immediately.
I will return the GOP table of 1080i in TYPE-ZERO2. Probably also in C1.5, I think that it will be satisfactory on the same GOP table as C1.4 in 1080i.
EDIT: Since there is a problem if completely the same, I am tweaking more. :-(
UPDATE!
bkmcwd Valkyrie 444 TYPE-ZERO2 Candidate1.6b 'Apocalypse Now' with cbrandin 'Pure Original 444 Matrix' and 'Modified 444 Matrix' - Seth.ini - Released 13/10/2012
*Please try C1.6b instead of C1.6.
NEW!
bkmcwd Valkyrie 444 TYPE-ZERO2 Candidate1.6 'Apocalypse Now' with cbrandin 'Pure Original 444 Matrix' and 'Modified 444 Matrix' - Seta.ini - Released 13/10/2012
This is the version which adjusted safer from C1.5 in HBR.
Please try this and compare with C1.4. And I am very glad if feedback can be got.
*If this is also still unstable, I will further adjust.
Special thanks to @har_k, @syoushow, @Tobsen, @peternap, @jul, @towi, @flaschus and @Berlin! :-)
Of course, thanks to @cbrandin and KING @driftwood!
*24p and 720p are the same as C1.5.
Superb-looking simulated 444 matrix from cbrandin
Modified 444 matrix from my BETA Team in Japan is adopted in HBR/1080i and 720p modes.
Upto 140M for Top Quality 1080p24 at Q18
Upto 140M for Top Quality 1080p30 at Q18 in 24L mode with 80% Slow-Motion Mode (No Sound)
Upto 75M for Top Quality HBR/FSH modes
Upto 75M for Top Quality 720/50p modes
Upto 50M for Top Quality 720/60p modes
Extremely reliable top performance in AVCHD 24H and 24L
80% Slow-Motion is available in 24L only
Fully working iA and iDynamic modes if you require them
Beautiful 3 GOP bringing short GOP style detail & movement-rendition in 24p and 1080i
Bush of Death / Death chart tested.
Wonderful Pasadena Pulse Audio Patch V2 B2, by Per Lichtman
Top quality 2K mjpeg Mode in HD by Nick Driftwood
In camera playback is sometimes not available in 24p. In other mode, available after reboot the camera.
                  Going to be testing C1.6 tomorrow in HBR 30 and will let you know how everything goes
@abraham1307 Many thanks for feedbacks! :-)
Since C1.4 was also frozen, I am just going to adjust C1.4 and C1.5 now. I am soory that C1.6 is not so good. In order to avoid confusion, I am going to release C1.4b and C1.5b. :-)
NEW!
bkmcwd Valkyrie 444 TYPE-ZERO2 Candidate1.4b 'Apocalypse Now' with cbrandin 'Pure Original 444 Matrix' and 'Modified 444 Matrix' - Setc.ini - Released 13/10/2012
This is the version which adjusted safer from C1.4 in HBR.
Please try this and compare with C1.5b. And I am very glad if feedback can be got.
*24p is the same as C1.4.
                  NEW!
bkmcwd Valkyrie 444 TYPE-ZERO2 Candidate1.5b 'Apocalypse Now' with cbrandin 'Pure Original 444 Matrix' and 'Modified 444 Matrix' - Seta.ini - Released 13/10/2012
Please try this and compare with C1.4b. And I am very glad if feedback can be got.
*24p is the same as C1.5.
                  I like C1.5b better than C1.4b. :-)
hello, I am new to the forum. Thanks for the great effort for this amazing hack. My question is next: when I record 24p cinema 12 minutes continuous and I stopped recording, next time I try to record again and a message appears on my camera "AVCHD is full" My card is 64 Extreme Pro 95MB / s, has not reached half. Only 2 minutes recording in 2k.
This is normal in this hack? sorry for my English
http://www.personal-view.com/faqs/gh2-hack/gh2-hack-faq
Known issues and bugs
There are sporadic reports of a “file number limit exceeded” error message when attempting to record with 64-GB SDXC cards. It looks like the problem is fixed by reformatting the card, and avoided by recording a short clip after spanning and before turning the camera off.
After the recording over 4 GB, before turning off the power, you should record a certainly short clip. Probably it solves now. :-)
thank you very much. That was fast response and problem solved.
Been using Valkyrie C1.5b in HBR 30p and i have been getting great results, and with no problems what so ever. I will post a video soon to show how great this setting is in HBR 30p. Once again thank you for creating my favorite setting thus far for the GH2.
@abraham1307 Many thanks for using Valkyrie! :-) I am looking forward to seeing your video.
@bkmcwd cheers for your hard work. I would like to know which of the valkyrie settings is in YOUR eyes the best for 24p at the moment? Cheers
@Mirrorkisser Hi, As a premise, 1.4b, 1.5b, and 1.6b are completely the same about 24p. Honestly, I cannot judge which is better between TYPE-ZERO2 and Flat4 in 24p. It is because I do not have time to fully verify "appearance" of FLAT4 matrix. However, considering that HBR of Flat4 is too going too far, I choose TYPE-ZERO2 from the standpoint of balance. And since I use Panny lenses, I choose C1.5b. Since I like "all round", I think that I will consider that C1.5b is formal TYPE-ZERO2. :-)
thank you!
@ GOLGOP3-13 lovers :-)
"GOLGOP3-13-A_Candidate 3" and "GOLGOP3-13-MAX_Candidate 3"
I release the each 3rd candidates for "GOLGOP3-13-A" and "GOLGOP3-13-MAX" settings.
This is the version which improved only 1080i/HBR of C2s.
Please try them! And many thanks for your feedbacks!
Special thanks to @towi and @flaschus! :-)
NOTE:
*Although bit rate setups are quite high, the bit rate which actually appears are lower than these. Since the actual bit rate changes by the object to shoot, please confirm by yourself.(Max bitrate : about 110M in 24p, about 75M in HBR.)
*These two settings are completely the same except 24p.
*24H and 24L are high quality 3GOP setting with mega size I-frames in GOLGOP3-13-A.
*24H and 24L are high quality 3GOP setting with super mega size I-frames in GOLGOP3-13-MAX.
*24p80%(30p) is available in 24H & 24L both.
*60i, 50i, HBR30p and HBR25p are also high quality and stable 3GOP settings.
*720/50p and 720/60p are 6GOP and 9GOP. It has tuned up so that the bit rate at the time of motion may go up rather than the time of statics.
*In camera playback is available in all rec mode except 24p in GOLGOP3-13-MAX, at least available after reboot the camera.(Not tested full yet, but probably)
*EX Tele, iA mode work.(Not tested full yet, but probably)
*Spanning in 24H, 24L with SanDisk 95MB/s 64GB SDXC Card. In other rec mode, need test.
                  Verification finished.
Both were satisfactory.
I am sorry to have disturbed. Please try them! :-)
I am also preparing GOLGOP3-13 as which a new experimental matrix was adopted now. I am going to release it to during this week. :-)
@bkmcwd 1.5 is a good choice IMO.
