SLR Magic 2x ANAMORPHIC lens
  • 804 Replies sorted by
  • @WashingtonIrving It's POINTLESS to make it in PL mount.
    There is only one full height sensor camera right now that can shoot with it, the Alexa Studio.
    A regular vanilla Alexa, RED, EPIC, F3, BMCC WON"T work with 2X without a substantial and pointless crop.
    jb
  • I really don't understand why you'd want 1.5X anamorphic adaptors. 1.3X is ideal and the most optimal for 16x9 sensor and 2.40 shooting.
    The ONLY 1.3 X anamorphics right now are the very nice but outrageously expensive HAWK 1.3x. You can only rent them and they are beyond the reach of most.
    1.3X anamoprhics would enable anyone shooting with a 1.78 camera to have 2.40 anamorphic. There'd be a lot of interest from even more middle to higher end shoots where the 1.3X hawks aren't practical.
    jb
  • @stip
    type '>' (without quotes) then simply copy - paste the text you want to quote.
    Thanks!
  • The detachable 2x > 1.33x adapter sounds like a golden idea... all the useability and image characteristics in one package, plus it's future proof if we ever get 4:3 image recording. I'd happily pay $1500 assuming build and IQ were there, especially if it could be used with wide angle lenses (really a 35mm equivalent is about as wide as I'd realistically need or want... if I could get good quality with my 17mm nokton I'd be in heaven).
  • @slrmagic I would certainly consider it.
    And I would be very interested in the idea above by john barlow (if possible) to make it decoupleable to 2x with proper mount (and use the same as attachment to lens).
  • @slrmagic
  • @stip
    Sorry not lens related but how does everyone reply with the blue bar and the quote like you did?
  • I would want 1.33 either way
    me too
  • I think it's a very interesting idea, especially if you make it possible to remove the last element and shoot pure 2x when needed. My guess is that we'll probably see more cameras in the future with the abbility to shoot 4:3, so it would definitely be nice to have the possibility of shooting 2x.
  • I would :)
  • Just a random thought. If we can somehow maintain the pronounced anamorphic ovals of the 2x or 1.5x on a 1.33x squeeze. Would everyone change their mind and rather have 1.33x?
  • Make the lenses 2x. If they're under $1k each people will buy them like hot cakes. And see how long it takes camera manufactures to add a 4:3 'anamorphic' recording mode to their cameras once customers start screaming for it. My guess is that the BMC will have this before the M43 version is released in december.
    Don't cave to camera manufacturers before you even start, make a good product and they'll adapt to you.
    Also, ideally they'd be PL mount and cover S35 frame. But hey, M43 will work for me too.
    I'm in favour of a T4 prime set. 12mm, 18mm, 24mm, 35mm, 50mm, 85mm.
  • Moving on, there is also the possibility of decoupling the third C cell leaving a standard 2x scope.
    Using a bayonet mount would be ideal for this, also the same bayonet mount would feature on the rear of the adapter, giving an accessory profit stream in bayonet mount to screw adapters for all the lens possibilities.
    Finally a zoomable adapter could be envisaged covering lenses from wide to tele
  • @B3Guy
    Basically yes, but for clarification see below
    The scope adapter scheme is A---------d1---------B---d2---C
    d1 & d2 are seperation distances (air gaps) of the cells A, B & C
    A & B are ana cells which combine to give 2x FHA, C is an ana cell rotated to make the total adapter 1.33x FHA
    The terms 2x and 1.33x refer to the in focus field. The out of focus Bokeh field will be different, for the same reason that a standard scope still leaves the Bokeh field vertically stretched (oval Bokeh)
    The R&D experimental rig should test for optimal values for d1 & d2. It may turn out that three adapters (combinations of d1 & d2) are best catering for wide,stadard and tele primes. Varying d1 & d2 will also affect focus and compatible focal length primes that can be used.
    Optical design is very much a Black Art and much experiment has to be undertaken. No one can promise that a design will work based on theory and paperwork alone. Even the top flight ray tracing and modelling sofware has difficulty modelling out of focus rays.
    Other considerations include weight and light loss and cost. Maybe moulded plastic cells could help with weight and cost.
  • @slrmagic John's idea is the best yet. maintain the effects of a true 2X anamorphic , then "desqueeze" to 1.33x with another anamorphic type unit at the back of the lens. (Did I get that right, @JohnBarlow?)
  • @slrmagic
    We were told people like pancake lens and anamorphic oval aperture shape before.
    I thought people don't like pancake because it's not easy to do FF on a tiny lens.
  • @slrmagic Visit https://vimeo.com/channels/anamorph and spend hours days weeks watching those anamorphic work. See it with your own eyes and feel the anamorphic :)
  • @JohnBarlow Well, as I've said, I'm not an optical engineer (although I've been thinking about taking a class or two in that). I'm fascinated, though - I'll have to do some reading for sure.
    @slrmagic Excellent! I'd love to see what sort of results you get out of it, even if it doesn't end up as the final design.
    Does anyone know if such a thing has been tried before?
  • @slrmagic
    Go and make this 'magic' lens :)
    and make it like art
  • @jackdoerner @JohnBarlow
    We had been working on this idea actually since a few days ago as it is better than digital crop or oval aperture disk.
  • Jack No, think about the double gauss scheme in your Helios. The front cell alone causes barrel distortion and some bright spark figured out if you flip it and put it as a second cell behind the front cell the pincushion distortion would cancel out the barrel distortion. This works for the in focus field except that the out of focus Bokeh still retains the barrel distortion, commonly referred to swirly Bokeh. Why this is so is the magic in optical design. The same concept will work for the squished Bokeh in an anamorphic.
    Search wiki for 'double gauss' for a detailed explanation
  • @JohnBarlow Wouldn't the prime have to be in the middle though? Otherwise it might as well just be a standard 1.35x anamorphic. The anamorphic bokeh is caused by light passing through the aperture after undergoing a 2x squeeze, so if you desqueezed it before the aperture, the net effect would be nil. For optical reasons, the aperture would have to be in the prime, so you'd have to have one anamorphic on each end to achieve what you describe.
  • @jackdoerner Jack the prime is at the rear :) just for clarification
    BTW The way I would approach this is to gather some anamorphic cells from used lenses and place them on an optical sliding rig and test and test. This is a cheap method for experimentation
    Tearing apart competitor products is standard practice which takes place in the bowels of companies secret room 1013
  • NDs are a very important cinematographer's tool, because (assuming you follow the 180 rule), the only other options for lowering light intake are stopping down the lens or changing the ISO. Changing either of these things will also change the aesthetic (aperture cahanges DOF, ISO changes noise). ND offers another way to change your light intake, but ND in front of the lens changes the aesthetic also. It cuts flare.
Start New Topic
Howdy, Stranger!
Sign In Register as New User
Tags in Topic
Top Posters
