Have you guys done any extensive tests with recording/editing video/audio files & projects onto SSD drives?
"SSD Drive" is redundant. :)
And @fatpig, yes. A 2.5" SATA drive has the same connector as a 3.5" SATA drive. You might want a sled if your case only has 3.5" bays, though.
I assume, it's not a problem to connect these to a desktop PC which has sata2, too? I have not looked at a 2,5" Drives connectors for a long time :)
Damn! I saw that and started the "That's great dance" but then I saw it was in Pounds, not Dollars.
This is good thing since motherboads are coming with embed SSD. Asus is giving 65GB SSD on their top line flagship models. System boot now is a reality on board.
Looks good.
System drive must be SSD without question.
