I got one with all mounting options today. And can assure that it is high quality item, very usable and even single hole clamp holds very good and tight.
I can attest that this is a solid product - I have the one with the dual 15mm rail mount, single 15mm hole was included too. The only criticism I would have is be weary of the hotshoe adapters, the tightening rings are too small and it tends to shift around pretty easily. I was able to get my set here locally for 200 RMB - not bad.
