I add grain with Final Cut Pro, rather than with Resolve . . . but that's because I use the free version of Resolve to grade my 16:9 anamorphic footage (1920x1080p, Resolve Lite's max resolution), then I export, desqueeze to 2560x1080 in FCP, and finally add the grain to "add" resolution to the stretched image. Gives a very nice 2.5k image ;)
@nomad Thanks! Do you use Clipwrap? rewapping could solve my workflow thoughts
Rewrapping is fast, it doesnt affect the files and if there is a need to work with ProRes I just can replace the H264 files in the Premiere's source directory with ProRes. Ich geb dir ein Bier aus ;-)
@peaceonearth I rewrap them to MOVs.
@artiswar, it's definitely easier and that's probably how I'd end up doing it too. But doing it in the grading room does give you the ability to tweak the grain layer or even use a key to only apply it to parts of the image.
@Oedipax Isn't it easier to add an additional track in the timeline for overlay?
The release version has a new feature (not in the betas from what I understand) that allows you to use a video clip as a matte overlay - perfect for adding grain right inside of Resolve.
Only downside to doing it this way is it looks like you have to add it on a per-clip basis, but it's also more powerful than doing it in the conform panel.
Also, BMD's servers must be getting slammed, my download of v9 final is coming in at only 150k/s.
I downloaded 9.0.0 lite 087 some minutes ago.
Last time I checked beta was available for quite a time.
Resolve is out of beta today http://www.blackmagicdesign.com/products/davinciresolve/
demuxed with tsmuxer and muxed the 2 elementary streams with mymp4boxgui - I also muxed as .mov just now, using ffmpeg- and the error stays the same. somehow there is black flicker over the image. (as before, every other image black) Additionally, the .mov file has really bad banding. some error with ffmpeg there. even though there was no recode.
How did you remux?
I just remuxed one of my short .MTS files, which was HBR to an MP4. Resolve recognizes it inside my project, which already contains a .MOV, but it does not recognize it on a new, empty project, which is weird. Sadly, resolve shows every second frame as black in the remuxed vid. not sure where this comes from.
Before and after grades attached. Native MTS with the EOSHD gamma fix on the left. Graded shot in DaVinci Resolve 9. Some weird audio bugs when using Scene Cut Detection. Just rejoined the audio in Quicktime Pro.
Does anyone have a special trick to get multi-cam (nested) sequences to import from Premiere CS6 (via EDL)?
Resolve manual says nested sequence import is not supported; maybe there's something that can be done in Premiere prior to the export to "un-nest" the multi-cam sequence?
Tried some avchd on b3 and they weren't recognized.
I did not find release notes for the beta. at least not on the bm homepage. It seems, only MOV and MP4 Containers are supported. Remuxing would be nice, is there any recommended option for this? All GH2 users could benefit from that..
My MP4 Files, which are H.264 5Mbps for YouTube Uploads can be used without a problem.
I think you can just register on site.
The link at mail.ru leads to a missing file. If anyone still has ClassOnDemand_DaVinciResolve.zip could you put it on Dropbox so I can download it ? Cheers!
Beta 3 is out. Hope it fixes AVCHD.
Do they have release notes for betas?
Here's a nice demo of DaVinci Resolve 9
Breaking News:V9b2 Base Memory All has been replaced by Reset All Grades and Nodes. Unfortunately they still have not listed it under the Nodes Menu. That is all.
Update to Version 9beta2 is out since Aug 8th
