I just installed the hack the other day and everything I have shot so far has been fine with the exception of the first couple of seconds of every video having the "blip," but today it figures when I go to shoot something important the video looks fine on the camera but when I do a log and transfer in FCP7, the video has constant choppiness and "blips" all over the place. It is now completely unusable. I thought that the problem might be log and transfer but then I tried to convert it with Toast Titanium and had even stranger results. The .mts file is almost 600mb but when I drag it into Toast, it says it's 2mb and when I export it, it just exports a 1 second clip of just solid green...?? What the heck!? There must be some way to save my video! I mean if it looks good on the camera playback then the file must not be the problem right? Someone PLEASE help me out here!! I was using recommended settings of 42000000 in 24H mode if that helps...
I played it fine in W7 64Bit WMP. But the clip didn't look great. You're using weird patch settings. 1080 progressive being checked hasn't worked all that well for me and your other settings aren't optimum. Check around the other topics for stable settings others have confidence in and try them.
@stonebat and @cosimo_bullo Ok, so maybe it could be my computer but just to see I have uploaded both the original .mts file and the prores 422 conversion that final cut made. Do either of them play smoothly on your computers?
I too just upgraded from a 2 year old mac laptop to the new i7 17, and now, finally, I'm getting clear playback of the AVCHD files without transcoding. Also, seems that apple has worked out most of the gamma issues now with Snow Leopard. About time!!!!
@sdbest I just did what I've done for every other video I've shot with the Gh2 since hacking it, SD card into card reader, plugged into macbook pro, Log and Transfer into FCP7.
@stonebat it's not a problem of speed, my computer plays the other 42mb/s files I've shot just fine. For some reason it's just this specific batch of files that are messed up.
Oh ok. Were you able to download it from the Sendspace link @Vitaliy_Kiselev or @kae? I'm at work now so I can't reupload until tonight if you need me to. Is there something wrong with the settings I used? Any thoughts vitaliy?
Could you post the EXACT settings file you used and the exact mode you were shooting in?? If it plays in the camera it should play blip free in your NLE, the reverse is not necessarily true.
Thanks...and one last thing, should I bother to keep these .mts files or do you think they're just corrupt? I just don't get why they play so smoothly in the camera...so aggravating!!
and to revert to the original firmware I just load the leaked firmware into Ptool and check version increment? Is that it or do I have to enter a number other than 1 for the increment?
This is unfortunately why this hack is still in testing, to find problems like this. I wouldn't recommend using anything other than original firmware settings on anything important for now until more research is done.
just copied the the Private folder from the SD card to the desktop and retried the log and transfer...same result. What could be causing this? Anyone having a similar problem?
