Our cinema RIG
  • 64 Replies sorted by
  • Progress...
    512 x 983 - 193K
  • Well, having used microforce zoom controls when I was operating on arris (backinnaday), I became very used to controlling zoom that way. There used to be an Israeli company that made them cheaper than the $6K models. I don't think they are around any more...
  • @rockroadpix
    There's more than one way to skin a cat
  • All cool ideas, but what is the use of a servo FF when you can't use it on a sound take?
  • @psycho, that shield controls either 4 dc motors, 2 steppers, or 2 servos :)
    Personally I am using steppers .. there are continuous rotation servos, and also ways to modify standard servos
  • Hey guys, after checking the USB back channel again, I'm sure it needs a USB host controller (as there was no simple on/off signal transmitted).
    So, I will go the Arduino way.
    Using an Arduino UNO and a www.iteadstudio.com Dual Step Motor shield 1.0 to controll a stepper motor from my Mac will be the first step. After that I will add a USB shield and incremental encoder to complete the package.
    @kavadni a servo won't work, as it is loud and has only a very limited angle of rotation.
    @andyharris thanks for the link to the stepper controll library - I hope it works with the iteadstudio shield?
  • @psycho .. I bought this as a starting point .. and an arduino .. and $20 bucks worth of prototyping wire and things .. http://www.adafruit.com/products/81
    Something to play with on my notebook during forced daytime renders.
  • @goanna @andyharris @kavadni you really got me convinced that the Arduion route is the way to go ;-)
    First I really have to check the USB back channel on my wireless system (how it responds to direct voltage pulses). But if thats turns out to need USB controller chips I will buy an Arduino package and learn how to programm it.
    With the Arduino it will also be possible to controll the focus motor from a Laptop with preprogrammed focus points. Quite some work ahead, but looks interesting. Thanks for all your input.
    PS: Stage 2 of my rig is nearly finished - hand held Steadycam system (vest and arm are stage 3).
  • And here is a link to a successful arduino project .. this has inspired me to order the servo motor shield they use
  • @andyharris thanks, missed that thread somehow.
    Can you give some more details what controller boards you where using and how that joystick is built?
  • @psyco
    Arduinos are simple enough, however note that the standard library for the Arduino is blocking. Have a look at this library:
    http://www.open.com.au/mikem/arduino/AccelStepper/
    This will simplify stuff.
    I used a similar approach on my crane head control:
    http://personal-view.com/talks/discussion/comment/78784#Comment_78784
  • @goanna thanks für the furhter information. So, I will need 2x Arduino Mainboards, 2x USB shields and maybe 1x motor shield - thats a lot of electronics :-(
    I think, going via USB is the most future proof way. But I'm still not sure if the Arduino will do, what I need it for - and all the desciptions I read so far about the USB shields don't tell me if and how I use them as a host device. I just don't want to buy all this stuff, figuring out how to work with it and then realize that it will never do what I bought it for.
    Have you used Arduino? Anybody else?
  • @Psyco I was only pointing out the Arduino as an option. Yes , if you stick with some sort of signal coming via USB, you'll need to get usb pins 2 and 3 from your wifi transmitter connected to your stepper motor driver (and yes a shield will do it, as in http://www.circuitsathome.com/products-page/arduino-shields/usb-host-shield-2-0-for-arduino).
    Once again, that's overkill. But in case you were hoping to connect the stepper motor to USB using analogue or logical pulses only, the ICs like nand-gate switches and buffers you'll need are already best used bundled into prototype stage circuit boards like Bssic Stamp, Pic and, best of all, Arduino. Once it works, you could look for something more elegant, (even a patent!)
  • @goanna Sorry, but its not as straight forward as you think, to get what I need. As far as I understand, you can't use the USB port on the Arduino board to send or receive signals (its only for uploading the software).
    I think @Meierhans is on the right track. So, you can set up one USB shield as host - I didn't find any information about that point - thanks.
  • @Psyco
    As I understand it, you need a computer.
    Yes, you use a computer, inasmuch as you write and test your program or "Sketch" and then transfer the compiled program to the Arduino:
    From Wikipedia: "It is designed to introduce programming to artists and other newcomers unfamiliar with software development. It includes a code editor with features such as syntax highlighting, brace matching, and automatic indentation, and is also capable of compiling and uploading programs to the board with a single click. There is typically no need to edit makefiles or run programs on a command-line interface".
    http://en.wikipedia.org/wiki/Arduino
    There are good books to begin programming; also sites like http://www.psurobotics.org/wiki/index.php?title=Arduino_Programming
  • There is plenty of variations/ripoffs of the arduino, from about 20 $ on up to 100 $. You would only need very simple ones for this task. You can one with usb shield in host mode an the the second one as client. Then either simulae te a serial or network connection via usb.
  • @goanna And how do you tell that board what to do? As I understand it, you need a computer.
    Having a laptop controlling the stepper motor would be interesting, if I want to use predefined (key-framed) focus points, but thats not my goal at the moment. I want a wireless user controlled FF with the least amount of electronics.
  • For example, this should do it although like using a sledgehammer to kill a fly..
    http://www.automationtechnologiesinc.com/products-page/3d-printer/ramps-pre-assembled-kit-complete
  • Arduino is a computer. I cannot imagine how it could not be done - even if you need to build a whole robot;-)
    http://arduino.cc/cgi-bin/yabb2/YaBB.pl
  • Thanks @Meierhans - it will be "awesome" when its completed to a full steadycam rig ;-)
    I had a look at the Arduino, but I'm not sure if it will do the trick...and 2 mainboards and at least 1 motor driver board and 1 USB board - its going to cost quite a bit.
    The point is:
    I will use an incremental position encoder which outputs two digital signals and a stepper motor which only needs two digital signals. So, I would only need something that passes these two signals through one USB channel.
    The hard part is, how to tell the USB controlers on the wireless modules to "just pass the signals to the other side and don't worry about the rest" ?
    I was even thinking on using audio d/a and a/d converters, but they probably won't work without a computer in the midle.
  • Indeed on of the best DIY rigs i have ever seen. Light and stable at the same time as it seems. Congrats! about usb backchannel: Guess there is no solution out of the box, but two arduinos could do the job.
  • Fully assembled rig (stage 1):
    Focus motor controll is still missing. Does anybody know how to controll a stepper motor via the USB back channel of the HDMI wireless transmitter without a computer?
    512 x 910 - 170K
  • @Alfi666 I was not talking about the low price chinese copies. I was talking about the American/European companies that sell the same parts for 3-5x the price but still use the same bold "design", instead of adding a couple of code lines to the CNC program and making the parts more usefull, light weight,... . They are just to lasy and to many people (with more money and less brain) pay for that BS.
    If I would have a CNC milling machine, I would start my own business - and I would call my rig "The Hiper DSLR Pro Cinema Rig" and sell it for 10x the normal price...and there would be my name in big golden letters all over the parts, and I would start to make big DSLR shoot outs with my gear,...hahaha;-)
  • @tonalt I got them from here: http://www.conrad.de/ce/de/product/237647/ACETALHARZ-STIRNZAHNRAD-M1-120Z (German online/shop)
    They are modul 1 cogwheels, so do not fit the normal FF gear which is modul 0,8. They come in 12, 15, 20, 25,... mm diameter - so maybe you can replace that cogwheel of your FF with one of these. They are very well made, easy to cut and have no play but still turn easily.
Start New Topic
Howdy, Stranger!
Sign In Register as New User
Tags in Topic
Top Posters
