Changing spring in FC-04H?
  • Has anyone tried to change the spring in the FC-04H head they bought though PV? When I bought the head I was shooting mostly stripped down, with only a mic, but now I find myself rigged up almost all the time with monitor, rails, ff, etc. So I'm pondering either buying a different head and using this one for my lighter set up or swapping out the spring. I have no idea where to even start for the swap out. Anyone with some guidance on how or whether it's worth the hassle?
  • 2 Replies sorted by
  • You need to carefully partially disassembly the head. Remove the top. Later use the side without any knobs.
    Spring is located directly inside.
  • @Vitaliy_Kiselev Thanks, I'll give it a try.
