i did another test with my new sandisk extreme 45MB/s mentioned above, in a GH2 , this time trying FSH (30i) with my same driftwood aquamotion v.2, but now with a pany zoom in autofocus, and the card span as well - getting 15:38 per block of 3.99GB. but with 24H, i was getting about 6:40 per block.
update: sorry for getting people confused ;/ the previous test was performed through sd card reader that was plugged into usb port... so when i thought more about it i realized that that is probably the bottle neck, and its not the cards fault. so did another one using express card port and sxs adapter and now transcend class10 reaches ~20,5MB/s average and sandisk extreme 30MB/s reaches 29.5MB/s average. that's more like it!
Would be nice writing down part numbers to identify these cards...
The B&H card part number is SDSDRX3-032G-A21
I have no idea where to get a death chart
There’s a bunch here: http://www.personal-view.com/talks/discussion/2017/importance-of-proper-tests-for-reliable-in-cam-playback-lessons-from-the-field/p1
i have a feeling that stores have not updated the pix on their website yet - J&R was showing the old HDvideo 30mb/s one. they sent me the 45 MB/s extreme. i'm curious to see what B&H is sending.
@balazer The card RawB posted is indeed the non-pro version but its not the HDVideo version I was talking about. RawB's the same as the one touviere7 posted above but the one I'm talking about is this one: http://www.bhphotovideo.com/c/product/828326-REG/SanDisk_SDRX3032GA21_32GB_SDHC_Memory_Card.html
Notice the HDVideo label, like the old 30MB/s version but it is now 45MB/s. I should be getting my 45MB/s card tonight so I'll run a few tests. Which one I will get though is still a mystery :)
It seems like there are possibly 3 different 45MB/s cards.
The insides of all 3 could be identical but with different labels. It seems SanDisk is releasing the 95MB/s and renaming the old Pro (45MB/s) cards to HDVideo and dropping the slower cards. Previously the Pro line was 45MB/s and HDVideo was 30MB/s so everything is being shuffled along as it were.
Slightly off topic but what are the "recommended settings" to stress a card out with? I plan on seAQuake with v1.0e FW. I'll probably be shooting a screen of random colour noise since I have no idea where to get a death chart or which the "best" death chart is.
Yeah - I'm also curious to know more about spanning on these new SanDisk Extreme [non-"Pro"] 45MB/s cards - was thinking of getting one since they are cheaper than the 95MB/s.
Thanks for your test result, touviere7. It's a very useful point of reference to know that the Extreme 45 MB/s card spans with Aquamotion v2 (88 Mbps GOP1). That would suggest it's at least as fast (for our purposes) as the HD Video 30 MB/s cards.
The next most useful things to know would be whether it spans at 146 Mbps GOP1 (Reaquanted, Seaquake), and whether it spans at 100 Mbps GOP3. (I can supply settings to test that. Flow Motion is VBR, and so not a good test subject if you don't know how to induce a certain bit rate.)
in reference to sandisk extreme SDHC I @45MB/s
i had ordered from J&R a 32GB extreme HD video @30MB/s and i received the new card mentioned above. my first reaction was to look on sandisk website - it's not mentioned. so i call sandisk and ask - they told me it's a replacement for the 30mb/s, fairly new, so not on the website yet. anyway, i did register my card on the phone, giving the serial# etc...
now, i just formatted the card in camera: GH2 with driftwood aquamotion v.2 - 24H cinema - poped a 35mm/2 nikkor and press record, camera sitting on my desk, but jerking it from time to time, changing focus... anyway. i stop recording after 34 minutes. no problem. span worked. see pix for results.
This is the benchmark I was speaking about.
http://www.tomshardware.com/reviews/sdxc-sdhc-uhs-i,2940-12.html
I don't know if computer test are useful to understand GH2 compatibility but I see that these Sandisk have a minimum write speed of 800KB. Maybe this could cause occasional write speed errors or spanning errors when GH2 IO buffers get full. From this benchmarks seems that the Kingston perform better on min write speed. Again, who knows if these test are useful in some way...
Not to' hijack the thread but in a tom's hardware benchmark posted here the Kingston performed better than sandisk. Is there Someone Who tested them against sandisk on a gh2?
@redpaw, it's  not (only) about what the card can do via your computer. You'll have to, for sure, what it can do in the camera. I've seen far too many "it should work, but it doesn't" I'm not counting on these kind of tests anymore.
@balazer, why would Sandisk make it easy...pff. Forget about my attempt. I'm curious to know whether the 45MB/sec version 'of Rawb' is any good, or we'll have to trade cards with somebody on some market...
Sustained write speed is just one performance metric, and not necessarily the one that predicts write errors and spanning failures in the GH2.
@redpaw, thats really interesting that the Extreme HD is showing the same speed as the Transcend class 10. I have been wondering lately, as the majority of my cards are Transcend class 10, why they are able to hold up pretty well using @Driftwood s newest hacks (Rocket and Orion) when some people are saying they have errors using thier HD Extreme cards. If they really are writing at the same speed, that would be why. Still saving up for a 64GB 95mp/s though
I did not put SanDisk item numbers in the FAQ because there have been different SanDisk cards to have the same numbers. Before there were Extreme HD Video 30 MB/s Class 10 UHS cards, there were Extreme HD Video 20 MB/s Class 6 HS cards with the same item numbers. You need to look at the box and the label and make sure they match what I put in the FAQ.
And FYI, the 30 MB/s Extreme and Extreme III (not HD Video) cards were discontinued a long time ago, and the Extreme Pro 45 MB/s cards at most sizes some time ago.
@sumo, the card Rawb pointed out is not the infamous Extreme Pro 45 MB/sec card. It's the new HD Video 45 MB/s card that is apparently replacing the HD Video 30 MB/s cards. None of us has tested the new cards yet, and we don't know if they perform similarly to the previous ones.
How about using HD Tune (can be downloaded here for free http://www.hdtune.com/files/hdtune_255.exe ) to check the real write speeds of the cards? i checked mine and here's what i got - sandisk extreme hd video (32GB) 30MB/s - hdtune: 19.9MB/s - sandisk ultra II (16GB) class 6 - hdtune: 17.6MB/s - transcend class 10 (32GB) - hdtune: 19.8MB/s - transcend class 6 (32GB) - hdtune: 18.5MB/s - transcend class 10 (16GB) - hdtune: 19.9MB/s
not really what i was expecting to see ;/ would be interesting to see what sandisk extreme pro's real speeds are
That's correct, but its just the numbers SanDisk puts on the label and the ones which are used by most members to identify the cards. On top of that, the camera might also be hindered for whatever reason to actually reach this maximum speed. Personally, in this case, I'd prefer to mention the articlenumbers.
I’d say this “writespeed” spec isn’t entirely accurate. I believe the numbers you see on the label refer to the maximum read speed. Write speeds will vary from card to card and are usually not indicated. (They may be indicated somewhere on the packaging with the regular “up to” disclaimer.)
Ok, time to make things clear as the FAQ also provides little guidance nowadays:
Name: 32GB SanDisk Extreme SDHC Class 10 (about to be EOL)
Articlenumber: SDSDX3-032G
Writespeed: 30MB/sec
Details: non UHS-I
Name: 32GB SanDisk Extreme HD-Video Class 10 (about to be EOL)
Articlenumber: SDSDX-032G-X46 Recommended
Name: 32GB SanDisk Extreme Class 10
Writespeed: 45MB/sec
Name: 32 GB Extreme Pro (about to be EOL)
Articlenumber: SDSDXP1-032G-X46 Not recommended
Name: 32 GB Extreme Pro Class 10
Articlenumber: SDSDXPA-032G-X46 Not recommended - get 64GB SDXC
Writespeed: 95MB/sec
Most cards do have a 16GB version too, but the HD-Video in general is tricky and I too encountered shops which did not have the 16GB version anymore and low on 32GB versions.
Please note the card mentioned above is an Extreme, not the Extreme Pro! The question is whether its a different card or actually the Pro with the Pro removed. Whatever the case, the favorite is about to become EOL without an affordable replacement. First thing is to find out whether the SDSDX-032G is too plagued with issues or not.
@RawB That's the card a few people are reporting issues with. Some people say it works fine but others say it doesn't work so good. The 30MB/s cards are supposedly the current recommended choice.
How about this one 16GB extreme 45mb/s, 29 euro (37 dollar): http://www.shopuniek.nl/webshop/geheugenkaarten/detail/77/sandisk-sdhc-extreme-hd-video-16gb-class-10---45-mbs-uhs-1.html
Don't know if anybody tested this card but it may have spanning issues with the more moddern hack.
deleted
Has anyone tried any hacks with a Sandisk HD Video 45MB/s card? This card looks exactly like the 30MB/s card in the first post but instead of 30MB/s its labeled 45MB/s. Its supposed to replace the 30MB/s HD Video according to my supplier. They have both in stock right now and I can choose either but I'm not sure which to go for... I have a feeling it could be the Extreme 45MB/s card that everyone says to avoid with a new "HD Video" label.
It's not exactly expensive so I wouldn't mind taking one for the team but it would be nice to know if anyone else has tried one :)
EDIT: OK, so looking on B+H's site reveals that the 30MB/s HD Video is discontinued and they recommend the 45MB/s HD Video as the replacement. I'm guessing people who want the 30MB/s should buy it sooner rather than later...
@Mr_Moore thank you for the clarification! time to upgrade the hackintosh to snow leopard or lion now!
