@Driftwood Thanks for Orion!
Driftwood Quantum X V4 Orion - 24p H works without issue, 24p L works without issue, HBR 25p no issues, using Nokton 25mm 0.95, iso160.
Short clips but the quality of the image is stunning! :o)
Of Course! New matrix and measurements for Panny firmware v1.1 / Ptools 3.64d
But Orion > 9b?
Orion = closest to Quantum 9b
@Pechente which 1.1 patch is the closest to 9b though? rocket3 or orion? this adaptive bitrate and constant bitrate stuff is starting to confuse me :p
HBR mode offers either 30p or 25p recording while 24H only delivers 24p video.
can anyone tell me the advantage of using HBR mode over regular 24H and vice versa?
FINAL Rocket v3 Release Candidate and Orion being uploaded right now. :-)
http://rene-henrich.de/Downloads/GH2-driftwood/00048.MTS http://rene-henrich.de/Downloads/GH2-driftwood/00050.MTS http://rene-henrich.de/Downloads/GH2-driftwood/00052.MTS http://rene-henrich.de/Downloads/GH2-driftwood/00053.MTS
More 25p HBR footage recorded with v3 rocket. Three of four times the same subject with different shutter and lens settings… yeah boring I know :D
@mozes Thanks for these screenshots. Looks like SpanMy... is holding up well. Are the clips overall looking good without probs?
driftwood@
Whats the best for 1080p (24p) ? Good work... ;P
"Quantum X 'SpanMyBitchUp' v2b"
Just back, damn battery was empty.
and "Quantum X 'SpanMyBitchUp' v2b"worked without any problem.
i HAVE ALL possible settings in the gh2 used, HBR. 24P in H mode, 300%, 80%.
720p 50, in SH and H, with and without tele2, iso 160 to 800, shutter from 1/50 to 1/1300, white ballans clouds. auto and manual focus
sandisk extreme hd video 32gb 30mb/s.
I will edit my files and upload it perhaps tonight.
Thanks for all your work man!
Can't wait to get my hands on a stable 25p/50p setting with the driftwood mojo loaded in it!
Ok, about to release 'Orion CBR' and 'Rocket v3 VBR RC' - final tests are going on.... :-)
@dirftwood, I am amazed. I just can't get the rocket to explode!!! Just the slight panning issue but even that for me is greatly reduced even from the earlier versions of Quantum I have used even in 24p. Really looking forward to try the CBR version and very very interested in the Driftwood Quantum X AVCHD-I 100/50.
GH2 Quantum Rocket V3 Sandisk 64gb SDXC 95 MB/s
Thanks all for this rapid testing... we'll have a final release candidate soon (RC)
tested1. HBR25p, 14-140@140, f14, ss125, iso200, 5600k, standard - STATIC
Ok, Think Ive found the issue. RC of Rocket v3 will be posted shortly.
Just did a quick handheld test with Rocket HBR V3 aiming the camera out against my window. Randomly it stops recording after a couple of seconds (resulting in battery pull). This happened at ISO 200, and sometimes when it works I can crank it up to ISO 3200 without any issues. If I first record a couple of secs in 1080 25p and then 720p it's fine most of the time, but sometimes the 1080p crashes before I get the chance to record anything. Even the Class 6 works sometimes, but all of the cards has a similiar pattern with the crashes.
This happens both with HBR 25p and manual 50p. Sometimes it works, sometimes is crashes. I've tested Sandisk class 6 and 10 ( all 30 mb/s and 45 mb/s cards).
Hope this helps! I'm probably doing something wrong here =P.
First test with Quantum Rocket V3 HBR 25p mode using sandisk 64gb SDXC 95 MB/s card. Converted MTS file to prores. Looks great! Slow acceptable panning cause some stutter/cadence issues. Looking forward to try the CBR version.
Second test with Quantum Rocket V3. Now I'm using panasonic 14-140 lens. I'm getting the same results than lumix-leica 25 mm.: Record stopped after 30 seconds. Camera hangs I forgot to mention that SD card used is Sandisk 64 GB 95MB/s
tested1. HBR25p, 14-140@140, f14, ss125, iso200, 5600k, standard - STATIC tested2. HBR25p, 14-140@140, f20, ss50, iso200, 5600k, standard - PAN
Sandisk Extreme 32Gb, 30Mbs
posting framegrabs and mts soon soon.
@driftwood Sorry, yes it was 25P HBR. I have tested all other modes as well with good result, but battery pull ones on FSH. Same panning. Sandisk Extreme Video.
First test with Quantum Rocket V3: I just shot 25 p HBR f 7.2 with shutter 160. Lumix-Leica 25 mm. lens. Record stoppes after a 30 seconds. Battery out
