Let's not turn already controversial topic into a mess about everything.
I already told my recommended range:
Panasonic 14mm F2.5, Panasonic 20mm F1.7, Samyang 35mm F1.4, Olympus 45mm F1.8, Samyang 85mm F1.4
i am planning to order
Canon FD 85mm F/1.2 L Lens & Voigtlander NOKTON 25mm f/0.95
for my gh2, are they good enough to cover a range in low light???
Vitality ------- i have a doubt ,..
which lens produce sharpest picture in gh2??? which is the best zoom lens which can also work in lowlight for gh2???
You don't need complete coverage and only low light lenses.
It is much better to go from the actual tasks.
As it is main beginners mistake going for complete coverage from ultrawide to extreme tele.
http://www.bhphotovideo.com/c/product/341297-REG/Pentax_C60812_C60812_8mm_to_48mm.html it has to be modified but its shocking what it can pickup in the dark. and its a zoom. i have like 5 leica primes and i just find fixed lenses boring now.
f2.8 Fisheye lenses might be an option as well. The image quality in the center is very good (you need only the center). I used the Sigma 4.5mm and the 8mm. I can recommend those. I also ordered a Walimex fisheye from ebay and had to return it. They are only f3.5 anyway ...
at 4.5mm Sigma 4.5mm 2.8 circular fisheye (only for EX. TELE but still wider than Tokina @ 11mm in normal mode. Needs rectiliniar correction in post like the optics compensation filter in After Effects)
at 10mm Sigma f2.8
at 10.5mm Nikkor f2.8
also: at 11mm Tokina 11-16mm f2.8 (for Nikon, to gain control over aperture with an adapter that has an aperture ring. Not very convenient but still better then Kipon adapter for Canon EF mount)
These 2 are the best lowlight super sharp lens i believe 10 blades for bokeh
anyone has these 2 together??
this lens is not very popular, I don't think you will find a lot of people here that has it. There are a lot of good 50 mm f1.4 lenses.
Philip Bloom tried it, and liked it : http://philipbloom.net/2010/03/10/review-of-noktor-f0-95-hyperprime-50mm-lens-for-micro-four-thirds/
But you know, there is something called Google that helps for that sort of questions, just write "Noktor 50 .95 review", you will find what you need. Searching on eBay is not the best approach to get info ...
what u think about this lens? anyone used?? samples?
Good post to look at : http://personal-view.com/talks/discussion/859/video-friendly-lenses-for-lumix-dslrs/p1
For extreme low light lenses :
wider than 12mm, there is nothing
at 12mm you have Olympus f2, or SLR Magic Hyper prime f1.6
at 20mm Panasonic 1.7, Sigma 1.8
at 25mm Nokton 0.95 and Leica 1.4
at 35mm, the lighter I know of is Voigtlander 35 f1.2 for Leica M mount, there are a lot more from f1.4 and upward
at 50mm the lighter I know of is Canon 0.95 for Leica M
at 85mm there is Canon fd 1.2, Nikon 1.4
Then it's more f2 or f2.8 (Canon, Nikon, Leica, ...)
