Here's the new smaller HDMI to composite converter
http://www.amazon.com/gp/product/B0080KN18K/ref=olp_product_details?ie=UTF8&me=&seller=
I just received a hdmi cable to RCA composite. It doesn't output any signal from the GH2. I was hoping two use two 7" LCD monitors I used for SD video. Maybe the cable is defected or the mini hdmi doesn't work with cable/box converters. I even used a powered hdmi switcher to help. No!
Too bad there is no analog video out while recording. Whish I could use my SD-Viewfinder on the GH2. it´s from the world´s first HD-camera ever, the HDC-500, built in1985. Even though the camera was HD with 1125 lines in 5:3 aspect ratio, the signal fed to the viewfinder was SD. I did modify the viewfinder to fit on a hotshoe for use with my XH-A1 added LED´s to illuminate the camera when working in dark places (like recording concerts) and even gave it a heated eyepiece... which is great for this winter´s temperatures... Oh, and I almost forgot my steadycam, which also needs sd-video-out
I read some ratings on amazon about the HDMI converter mentioned above. As far as I understand, the hdmi converter´composite video is not sharp. Could anyone confirm this?
@gizmo: great price for the converter!
@la_turbine it's been talked about a lot before, but for whatever reasons it doesn't seem like it will happen anytime soon (analog out while recording that is).
What I am confused about now is the actual modes the GH2 is recording in while using HDMI output for video monitor. Does anyone have a clear idea if the hack effects this or if v1.1 firmware is any different (it appears to be in my testing so far)??
Thanks all for answers ! I will test one of those cheap hdmi converter. Since the camera is outputting analog video while framing but not when recording it puts me in rage because everything is here, just a F*#&57G stupid limit of the GH2 enginers... Perhaps is there a good reason. It could be easy to swap the function perhaps? The output via the LCD screen is still working when shooting, no?
