@markmark1 in AE set video 'Stretch' to 2-5%. CC Force Motion blur with settings: Motion blur samples:8 (more - better but slower. depend on stretch value) Shutter angle - 180. Thats all
@balazar Sorry if this is a newb question, but how exactly are you able to set a shutter speed of 1/2 second? With my camera, I'm unable to set anything slower than 1/25. Is there a hack option that I'm unaware of?
AVCHD 1080p is real 1080p. Lowering the shutter speed to 1/2 doesn't change that. Setting the GOP length to 13 yields the same video quality as GOP=1, since you get one I-frame per picture taken. Just make sure you use the I-frames in decoding. (my Avisynth script accomplishes that with the SelectEvery(13) expression)
@balazer how long can you record if you would come to 2GB. Compared to the MJPEG (approx. 1 hour at 1080p, 2GB and 2ps) will you save lot more space on your card.
Either my ability to test is compromised at this hour (which is entirely possible) or you're right (which is even more likely). :)
There's a decent chance I got frame blending and field blending mixed up, in which case I apologize for the confusion. I'll check again when I'm a bit more alert.
You can go even further, if you are willing to export to image sequences. :)
One of my favorite approaches is to use averaging instead. There are tons of more complex programs for this purpose, but Photomatix Pro has a batch averaging mode that lets you combine anywhere from 2 to 12 exposures per frame (with the added benefit of noise reduction smoothing).
The math is: # of exposures to average X 100% = playback rate as percentage
So you can get 200% to 1200% playback rate easily that way.
In my experience with both, the results are a lot more rewarding with averaging.
