I'd guess #2 is gh2, but really - it's incredibly difficult to tell straight up because we do not know how these are exposed in camera. (and I for one do not know how all these cameras look in respective modes) Basically, you can tell that the first image is done with a large sensor because of the short DOF / slight vignetting. I'd guess that one is the 5d, but nothing is certain. #2 looks a bit like how I would expose the scene with the gh2, hence I think it is that one. Also, the halo's from the bokeh looks familiar.
From such shots the important thing is how they grade and some looks a lot easier to work with than others.
Well speculating will probably only make me look like an idiot, but the only thing that makes me think 2 over 5 for the gh-2 is that the hair on 5 seems has a little too much contrast.
#5 has the least amount of banding and macroblocking/pixelation...(looking at the background of all pics in the same place; between the right corner and the model's hair)
i believe #1 is the sony, because of the bokeh, it has the biggest lights in the back, that should be related to the size of the sensor right?, so bigger light spots = smaller sensor and backwards, smaller light spots = bigger sensor
Could be, I for some reason associate a green tint with canon footage, but since they weren't shot in the technicolor cinestyle they would probably look the closest to actual color straight out of the camera.
So for the skin tones: #2=GH-2, #3=af-100? 2 just a little yellowish tint from nostalgic, 3 AF-100 always a little contrasty. Trying to use those background lights for DOF but he could have been tricky and moved them. I usually shoot in smooth so not 100% sure.
The 70Mbp/s Philip reports on his picture caption was yielded from the L setting shot. He does have 150Mbp/s material on his SD card which will follow when the report is written up ;-)
My little GH2 is a great camera, and just keeps on getting better, thanks in no small part by all of you folks round here! So a big thank you to VK, ND and all of those helping!
I hope to avoid too much discussion comparing this fantastic filmmaking tool that I am happy that I own, with a bunch of other equipment that would find it difficult to afford! I know that for me, seeing a bunch of higher spec. equipment and what it can produce.. is not likely to help my situation, so I think I will try to enjoy my camera without looking too hard at the details :)
I did say "I will try" Looks like the driftwood hacked GH2 beats the £4000 AF101
Which film mode is he using? If it's sth like cinema, the GH2 is destined to fall flat and look like a AF100-disgusting highlight roll-off and crushed shadows. Now if he's using -2 -2-2-2 smooth or white balanced nostalgic or even standard, + quantum V5 at 24H, then we're in business.
