Sony G Master Lenses
    New G Master line-up consists of a 24-70mm f/2.8 standard zoom, an 85mm f/1.4 prime and a 70-200mm f/2.8 telephoto zoom plus two tele-converters.
    PR
    Sony Electronics, a worldwide leader in digital imaging and the world’s largest image sensor manufacturer, has today introduced their flagship G Master™ brand of interchangeable lenses.
    Sony’s new brand includes three new E-mount full frame lenses including a 24-70mm constant F2.8 standard zoom, an 85mm F1.4 prime and a 70-200mm constant F2.8 telephoto zoom. Representing the ultimate blend of high resolution and beautiful bokeh, the new lenses feature Sony’s innovative optical element technology, design and calibration. This allows them to produce still image and video content with a level of detail and expression that has never before been possible.
    “The new G Master brand represents the finest and most impressive group of lenses that Sony has ever brought to market,” said Neal Manowitz, Vice President of Digital Imaging at Sony Electronics. “With our knowledge of what the future will bring for digital imaging, we have designed these lenses and can ensure that the G Master brand will inspire and ‘wow’ photographers and videographers for years to come.”
    FE24-70mm F2.8 GM Standard Zoom Lens
    Featuring some of the most advanced lens technologies in market today, the new FE 24-70mm F2.8 GM (model SEL2470GM) is the ultimate choice for those seeking the highest possible optical performance for portrait, travel and event photography or even simple everyday shooting1.
    The new lens is built with three aspherical elements including a newly developed, extremely precise XA (extreme aspherical) element that reduces aberration and delivers the ultimate resolution throughout the entire zoom range and aperture range, as well as from corner to corner of all image files. Additionally, an ED (Extra-low-Dispersion) glass element and Super ED glass element keep chromatic aberration to a minimum while maximizing resolution and bokeh without any unnatural coloration.
    The lens features a 9-bladed aperture that maintains a near circular shape at all settings and is coated with Sony’s original Nano AR coating to suppress reflections and ensure spectacular contrast and clarity.
    The new FE24-70mm F2.8 GM lens has a direct drive SSM (Super Sonic Wave Motor) focusing system that works with incredible efficiency thanks to a new set of algorithms that positions the lens elements quickly and accurately. The motor is smooth and quiet, making it an ideal choice for shooting both still images as well as movies.
    To maximize usability, the lens is dust and moisture resistant and features a compact, streamlined design that includes AF/MF switch as well as focus hold, zoom lock and hood release buttons.
    Two new matching filters for the FE24-70mm F2.8 GM lens have also been introduced, including the VF-82MP MC protector and VF-82CPAM Circular PL filter..
    FE 85mm F1.4 GM Telephoto Prime Lens
    Designed as the ultimate portrait lens, the long-awaited new FE 85mm F1.4 GM telephoto prime lens (model SEL85F14GM) strikes a perfect balance between resolution and bokeh in a compact package.
    The lens features a new XA (extreme aspherical) element as well as three ED glass elements that work together to ensure that the in-focus areas are captured in extremely high resolution while the surrounding out-of-focus areas dissolve smoothly into a beautiful soft backdrop. It has a circular aperture with 11 blades – the most ever used in an α lens – that ensures bokeh is smooth and visually appealing. Externally, the new model has Sony’s original Nano AR Coating, which is of particular importance in a portrait lens as it reduces flare and ghosting, even with backlit subjects or similarly challenging lighting conditions.
    For accurate autofocusing, the FE 85mm F1.4 GM lens includes a ring drive SSM motor system that provides ample power and speed to drive the lens’ large, heavy focus group. It’s also equipped with two position sensors to support flawless focus control of the large, heavy lens elements.
    This new professional portrait lens is dust and moisture resistant and also has an aperture ring with on/off switchable click stops that can be adjusted based on whether a user is shooting still images or movies. It also has an AF / MF switch and a focus hold button.2
    FE 70-200mm F2.8 GM OSS Telephoto Zoom
    Covering the frequently used 70-200mm focal range, the new FE 70-200mm F2.8 GM OSS telephoto zoom lens (model SEL70200GM) offers extremely high rendering, AF performance and image stabilization, making it a versatile choice for shooting wildlife, sports, weddings and a variety of other events and locations.
    The new flagship telephoto zoom model delivers extraordinary sharpness and clarity throughout the entirety of its zoom range thanks to its three advanced lens elements including XA, Super ED and ED glass components, as well as its Nano AR coating.
    The new FE 70-200mm F2.8 GM OSS lens features a floating focusing system – implemented in an α zoom lens for the first time – that contributes to an impressive minimum focusing distance of merely 0.96m and ensures AF performance is optimized during both still and video shooting. The lens includes a SSM (Super Sonic Motor) plus dual linear motors that work together to move large lens elements quickly - a task that requires a high level of drive control and ensures focus accuracy. The new model also has built in Optical SteadyShot™ image stabilization for capturing sharp, blur-free subjects at all focal lengths and a rotating tripod mount that allows the camera to be quickly removed from a connected tripod as needed.
    The new 70-200mm telephoto zoom lens is dust and moisture resistant with an additional fluorine coating added to the front lens. It also has a focus hold button as well as a focal range limiter.
    Sony has also announced new compact 1.4x and 2x Teleconverters – models SEL14TC and SEL20TC respectively – that offer even greater reach while maintaining the overall streamlined design and feel of the 70-200mm lens.3
    Pricing and Availability
    The new FE 24-70mm F2.8 GM Standard Zoom and 85mm F1.4 GM Telephoto prime lenses will be available in March for about $2,200 and $1,800, respectively.
  • 155 Replies sorted by
  • 70-200mm GM lens firmware v3.0 released
    improves AF operation stability under certain conditions
    https://www.sony.com/electronics/support/lenses-e-mount-lenses/sel70200gm/software/00262877
    709 x 600 - 77K
  • Sony FE 70-200mm F2.8 GM MTF Measurement
    70mm
    200mm
    630 x 700 - 80K
    621 x 703 - 77K
    800 x 536 - 59K
  • Sony FE 70-200mm f/2.8 GM OSS Review
    70mm
    *200mm**
    http://www.opticallimits.com/sonyalphaff/1044-sony70200f28gm
    516 x 367 - 43K
    510 x 375 - 43K
    800 x 537 - 70K
  • 85mm video sample
  • Review
    Center sharpness at 70mm is high from f/4 to f/16, with f/22 being adversely affected by diffraction. The edges aren't quite as sharp as the center, with f/5.6-f/11 producing the sharpest results.
    At long end, 200mm, center sharpness remains high through from f/4 to f/16, with f/22 being adversely affected by diffraction. The edges aren't quite as sharp as the center, with f/5.6-f/11 producing the sharpest results.
    http://www.photographyblog.com/reviews/sony_fe_70_200mm_f2_8_gm_oss_review/
    800 x 521 - 93K
  • 70-200mm Ver 05 Firmware
    This update (version 05) improves the accuracy of the contrast AF at distant shooting, making it easier to focus when the aperture is narrowed down to F11 or higher..
    https://esupport.sony.com/US/p/model-home.pl?mdl=SEL70200GM&template_id=1&region_id=1&tab=download#/downloadTab
  • 70-200mm Ver 04 Firmware
    This update (version 04) resolves an issue where some products may not operate properly after updating to version 03.
    Note: The lens must be attached to an E-mount body camera to perform this update. The NEX-5, NEX-3, NEX-C3, NEX-VG10, and PXW-FS7 model cameras cannot be used.
    https://esupport.sony.com/US/p/swu-download.pl?mdl=SEL70200GM&upd_id=11327&os_group_id=6
  • 70-200mm Ver 03 Firmware
    This update (version 03) improves AF-C (continuous AF) performance for zooming when attached to an ILCE-9 camera (requires the latest ILCE-9 system software update).
    https://esupport.sony.com/US/p/swu-download.pl?mdl=SEL70200GM&upd_id=11282&os_group_id=28
  • Sony FE 24-70mm f/2.8 GM vs 24-70mm F/4 ZA OSS
