@oscillian I put a piece of tape on the ring of the 45mm and then put the GH2 into MF mode where it displays the focus range. Rotating the lens through the entire range (as shown on the screen) is just over one full revolution, almost 1.2 times around. If you like long throw focus, then the Vivitar 55mm macro is a lens you should also consider, although the throw is more like a log scale. I have never had focusing issues with the 45mm; some of my old Nikkor glass (which is really contrasty) is so touchy if you bump the tripod the focus can move.
Olly is marketing its new lens as the "portrait" lens, but the 45mm is a bit closer to portrait length. They should make a 60mm/1.2!
@LongJohnSilver Yashica makes some great glass! There just is a kind of saturation of good choices at the 50mm end.
It's strange that nobody cites the Yashica 50mm ML f1.4 and ML 1.7. Not to be confused with the mediocre MC version. Maybe you are victims of Lock-in :)
They are the poor man Zeiss. Near the same quality of the zeiss counterpart. You can find them for $100 or less.
With the 24mm and 28mm ML f2.8 they are one of the best hidden jewels out there.
@tesselator used the 24mm for the pics of the lens he sells.
http://www.personal-view.com/talks/discussion/comment/3463#Comment_3463
@DrDave Thanks for the info! How long is the focus throw? I'm pretty spoiled by my Voigtlaender 25.95 and FDs when it comes to manually tracking the brides eyelashes in my wedding videos ;) 45mm seems like a sweet spot for portrait framing on the GH2. 50 is too long indoors and 25 is intimidating on the client some times.
Olly 45 is good in MF mode. In fact, the Olly 45 stays ON the camera, the 14 and 20mm stay in the bag, and all the other lenses including the Nikkors, Rollei, Leica, Minolta and even the JC Penney stay in the lens cabinet. Sorry guys, y'all are fuzzy wide open and stopped down you still lose by a hair. I may have to cave and get the new Olly telephoto if it can beat the Samyang. Every now and then I use the Vivitar 55, just because it looks so good for no apparent reason.
Though not a '50' and not 1.x - i like the CV 40/2 - pancake sized and comes with a macro filter. Super sharp wide open ans great build quality.
I like my Rokkor 50mm F1.4s I have the PG and X lenses, also like my 50mm Ziess Jena 50mm F1.8..
My Rokkors are cheap ebay buys (under $50) for the most part (have a few of them) and at F2.0 they are nicely sharp. 1.4 they are a bit soft but still usable, some times the softness really helps cover rough skin or other issues.. Softness can be a great thing depending on the situation.. Like older talent.. Hide the wrinkles a bit.. I have a decently large selection of lenses and use many often and my cheap 50mm Rokkors are one of those "go to" lenses.. Rokkor prmes in general are pretty decent.. I have a wide selection of Rokkor primes... Mainly because they are still cheap and deliver good results. People comment (positively) all the time on my photos and video, and they are usually on a Rokkor lens.
Rokkors are not perfect but they are good for next to no $$
Get a nice clean copy and I bet you'll like it.
@Vitaliy_Kiselev Is the Pentax SMC 50mm 1.7 any good wide open? I have the FD 50 1.4 and always use it at 2.0 to avoid coma/softness. And how is the Olly 45 in manual focus? By-wire-plastic-fantastic or butter-smooth-nail-that-follow-focus?
