China launches Chang'e-5 lunar mission - huge warning to US
  • 61 Replies sorted by
  • @fostonpete
    It's really, really hard to hit and took a while to get a decent return signal even with a big ass pulsed laser that sounded like a small machine gun.
    Did you see text above, as talk is about single photons, not just weak signal.
    I talked to two guys who immigrated into EU and US and kind of participated in experiments that involved reflectors in some part (as tech guys and not very direct), but as soon as they started asking out general details about results (not about nice paper reports), about reflectors, signal levels - all instantly turned into big hostility towards them, they had been told to shut up and "understand importance of our mission".
  • I have 'shot' the retro reflective mirror on the moon from my universitiy in 1995. It's really, really hard to hit and took a while to get a decent return signal even with a big ass pulsed laser that sounded like a small machine gun.
  • Yes, even the landing video flying over the moon in first video looks like plaster of paris with air bubbles :)
  • @jleo
    Last video btw shows how you can shoot fake landing with super accurate surface image :-)
    With modern tech it is faster, but at Apollo days had been very similar.
  • China’s Chang’e-5 lunar mission has successfully landed on the near side of the Moon, near Mons Rümker, a volcanic complex in the northern region of Oceanus Procellarum, on 1 December 2020, at 15:11 UTC (23:11 China Standard Time). The Chang’e-5 lander will attempt to collect about 2kg of soil samples and return them to Earth.
  • By the time the beam bounces off the mirror and returns to Earth, it has widened to about 12 miles (20 kilometers) in diameter. This beam dispersion makes it more difficult to view the reflection.
    The reflector itself doesn't require any power, which is why it's still operating decades after other instruments on the moon fell silent. This instrument includes 100 "corner cubes" (or fused silica half-cubes), which are placed in an 18-inch-square (46 centimeters square) aluminum panel, according to NASA's Jet Propulsion Laboratory (JPL). It's due to the shape of these corner cubes that any laser shot at them reflects light directly back.
    "Once the laser beam hits a reflector, scientists at the observatories use sensitive filtering and amplification equipment to detect any return signal," JPL said. "The reflected light is too weak to be seen with the human eye, but under good conditions, one photon, the fundamental particle of light, will be received every few seconds."
    Observations must be made over several hours to account for the weak signal.
    Actually it means it is zero proof that reflectors play any role it getting "one particle of light" here.
  • @Vitaliy_Kiselev
    Come on! Its not a flat mirror - of course that would be bullshit O.o
    Its a "cats eye" reflector, so will allways reflect back at source location. And you pulse the laser which will help in filtering out any light contamination from earth atmosphere and the rest of the surfcace of the moon.
    Without a mirror like that, the tiny distance shift of the moon from year to year would be impossible to measure.
  • @Psyco
    Just ask somebody you know at an observatory to point one of there teleskope lasers at the given coordinates - and see if there is a reflection. Let us know about the result.
    You just repeating mass media bullshit.
    If you think a little, in our reality laser spot size at such distances is huge (even for best focused lasers), reflector is not even surface that is directly perpendicular to your location (so it'll reflect this tiny amount of radiation into some random spot in space), real moon has quite high albedo and it'll actually reflect 99,9% of remaining part of your laser radiation (just at random directions, so not big amount will get back, but it will be much much more compared to even perfect reflector). So it is real total mess.
    In reality all measurement are being done similar to how laser distance meter is working in life (but lot of things are very different!). So, yes, reflection from the moon ground is used.
    You can make experiment with laser and any random oriented(! this is important) reflector placed only few hundred meters to 2km from you, you won't get a shit.
    Btw watch how Chinese are doing all stages of flight and will do landing and how it is huge sharp contrast with Apollo fake bravado.
  • @Vitaliy_Kiselev
    If there is NO reflector on the moon, how do you measure the drift into space of it?
    (I'm not speaking in favour of the US, its only about that mirror that someone placed on the moon - I don't care who did it.)
  • @Psyco
    This reflectors are quite fun, NASA even paid to Big Bang Theory authors to make episode on showing how they can be used. Just some time after this authors told that all had been total lie (they can't be used such as showed and it is actually big issue with this reflectors and if they are actually present), but "it helped in our war with moon landing deniers".
    NASA makes you think like it is simple and no biggie and it is "total proof". But if you dig deeper - it is mess. Modern (last 5 years) instructions for NASA sponsored guys is not to use them and do not go into even mentioning them.
  • @radikalfilm
    https://en.wikipedia.org/wiki/List_of_retroreflectors_on_the_Moon
    These reflectors where needed to measure the exact distance to the moon, which led to the discovery that the moon is moving away from earth (a rising full moon some million years ago was quite show ;-)
  • @Nino_Ilacqua
    Arguments in this thing are quite old.
    Falsification of landing is pretty cheap to do and not require any CGI.
    Do not know about US, but even is distant Mordor we have 4-5 widely known people who get full time salary (around 4-5x of salary of same local offers) and their official job is go around and support NASA (both offline and online, as it is full time job). Some of them are required to make similar videos and send reports of their doings. One of them some years ago openly told that all 100% of photos, arguments and video parts had been sent to him directly by NASA (but they asked that is should be presented as independent arguments). Officially NASA is not involved in all this directly, btw and always deny it.
  • I find this video pretty convincing. It’s the actual video of Apollo 11 landing side by side with a google simulation. It seems to me the landing was really.
  • @radikalfilm
    these are very tall claims to make! Not only the entire Apollo program, but much of the Mercury program too would have to have been faked!
    It is actually only very mild statements. But causes had been purely technical and organization. yes, and von Braun played big role also.
    Disputing the actual landings is one thing, disputing orbital capability is quite another. Not even Sputnik (the Kremlin propaganda media agency) would dare making the claims you make, for which of course you have no evidence.
    Disputing US moon program actually (in all serious guys whom I checked) start from early suborbital flights (US had been also open that they are suborbital).
    You will be surprised, but actually guys who infiltrated soviet space program worked hard to destroy as much as they can. Now our space agency is mostly bad joke that live on the remains of great institutions and factories, but they are going down one by one. Recently they closed in Moscow some core of them as making cheap buildings and selling them via credits is more profitable for new owners (in the range of 3-4 years until they will flee into EU).
    What about the Soviet program, Vitaliy? Did the Laika doggie make orbit? Did Gagarin make orbit? If he did, why couldn't von Braun replicate what the USSR-bound portion of his Peenemünde team achieved?
    All is ok with soviet program. CIA and NASA had direct access for around 4-5 years during early 90s to check and steal lot of stufff.
    Because USSR made huge new industry with tens of thousands of new specialists and hundreds of factories, at least 15 new big science research facilities, contrary to US, who still focused on von Braun.
    USSR started to be worse in computers and electronics, but only due to the fact that elite group who finally made USSR destruction in 86-91 years already got tight grip on this sector in late 60th (but due to organization they did't have access to some military part of electronics and corresponding factories).
    Important aspect also is geography, as US did not care so much on efficient very long range missiles (having much better carriers, bombers and ability to put nuclear missiles in EU).
  • @Vitaliy_Kiselev these are very tall claims to make! Not only the entire Apollo program, but much of the Mercury program too would have to have been faked!
    What about the Soviet program, Vitaliy? Did the Laika doggie make orbit? Did Gagarin make orbit? If he did, why couldn't von Braun replicate what the USSR-bound portion of his Peenemünde team achieved? I find your average theories ~60% possible, and ~40% probable, but this one is jumping the shark. Disputing the actual landings is one thing, disputing orbital capability is quite another. I'm not a US citizen, so there is no patriotism involved. Not even Sputnik (the Kremlin propaganda media agency) would dare making the claims you make, for which of course you have no evidence.
  • @jleo
    As NASA at the Apollo time still couldn't even make rocket to go around the earth one time (all rockets, including all Apollo ones just fall into ocean not getting enough attitude) - they did not care.
  • Hmm. if they went to the moon so many times, why didn't they measure the radiation on those missions?
    "Radiation on moon's surface measured for the first time, study says
    When the next astronaut to reach the moon walks on the lunar surface in 2024, she'll face radiation levels 200 times higher than on Earth. While Apollo mission astronauts carried dosimeters to the moon to measure radiation, the data was never reported.
    The first systematically documented measurements of radiation on the moon were undertaken in January 2019 when China's Chang'e 4 robotic spacecraft mission landed on the far side of the Moon, according to a new study in the journal Science Advances. Astronauts on moon missions would experience an average daily radiation dose equivalent to 1,369 microsieverts per day -- about 2.6 times higher than the International Space Station crew's daily dose, the study said.
    "The radiation levels we measured on the Moon are about 200 times higher than on the surface of the Earth and 5 to 10 times higher than on a flight from New York to Frankfurt," said Robert Wimmer-Schweingruber, a professor of physics at the University of Kiel in Germany and the corresponding author of the study that published Friday, in a statement.
    https://www.cnn.com/2020/09/25/world/moon-radiation-astronauts-exposure-scn/index.html
  • People are more likely to develop health issues with extended time in space, such as cardiovascular and sleep disruptions. But why? Scientists might have an idea. They’ve published research indicating that mitochondria, the energy-producing “powerhouses” of cells, may play a key role. Bodily fluid samples from many other astronauts also supported claims that mitochondrial activity changed while in space.
    The potential breakthrough came in part thanks to NASA’s open-source GeneLab platform.
    The findings reinforce concerns that astronauts could face significant health challenges going forward, particularly for trips to the Moon and Mars. The discovery could be crucial to overcoming those problems, however.
    Note that all 100% NASA fake moon trips had zero health issues and overall they felt like even better than before the trips.
    Problem had been that NASA at the time had zero knowledge of real problems that happen during such trip.
  • @bannedindv
    I don’t think many would give a shit in the US if this is the case. Personal identity for most here is so so far removed from that kind of nationalism on technology. The new god here is the self not the nation. Selfish motherfuckers here.
    You are badly wrong.
    For example, even in Mordor locally any NASA sponsored so called "space influences" (we have around 7-8 of such, google push them hard) have main goal - proving at each and every public talk (even not related) that Apollo missions had been all real and anyone who doubt it are morons and must be punished (in recent 2 years they call for total censorship!).
  • I don’t think many would give a shit in the US if this is the case. Personal identity for most here is so so far removed from that kind of nationalism on technology. The new god here is the self not the nation. Selfish motherfuckers here.
  • If Chinese proof USA wrong, it will be one of the most humiliating things exposed ever. All boomers from USA will get depressed and young people raged!!
  • @Psyco "so many possibilities" exactly, however I don't think there's a scenario where the Chinese could prove beyond doubt the US landings didn't happen, even if it were actually true. They'd be "cancelled", explained away, or dismissed as propaganda. All they could do convincingly is confirm the landings did happen, if they actually did :-)
    This mirror that you speak of, does it have known coordinates? Can anyone with the proper laser and targeting bounce a signal off it? This is independent 3rd party confirmation. Still, the mirror could just be on the back of a rover, and rovers have been done for sure, by the US, USSR, and recently China.
  • Fun discussion ;-)
    But one thing: The USA landed on the moon at least once, as there is a special mirror positioned on the moon for distance measurement (still in use). Weather this landing was one of the "official" ones and if there where any others... I don't know.
    Oh, and Chinese could land on the moon and clean up (remove all US remanents) and then "show" the world that US is lying. Or they could just fake there own landing and show a clean moon to the world... so many possibilities.
  • If it wasn't faked, they would find artifacts left on the moon, including:
    Bottom half of Lunar Module/Lander
    TV camera
    Tools, shovels
    Objects and equipment for scientific experiments
    The Lunar Roving Vehicle (LRV)
    Various personal artifacts, golf balls, Apollo 16 Charles Duke’s family photo
    Disposal Bags of human waste
    US Flag
    footprints on surface, if not worn away
    If faked, where did the moon rocks come from? A meteorite from Papua New Guinea?
    If faked, Biden has to really rush to plant those things on the moon ASAP :)
