Seagate HDDs with SMR secret usage that is not indicated in docs or markeitng materials
WD HDDs with same "feature"
SMR drives are very slow during recording, especially on full drive (up to 5 times slower, IOPS up to 10x worse).
It is very tempring to use such tech for companies as they can use lower quality platters or same platters but increase HDD capacity.
Using SMR (it adds 15-20% to drive capacity) adds  around $0.2-0.5 to drive cost. Companies sell you SMR drive for exactly same cost, so all this avings go 100% to their profits.
Toshiba actually do the same
Toshiba had been forced to admit that also secretely moved many models to SMR.
Tohiba 3.5" HDDs
Toshiba 2.5: HDDs
Wd seems to lost all manners
WD Red HDDs have for many years reliably powered home and small business NAS systems around the world and have been consistently validated by major NAS manufacturers. Having built this reputation, we understand that, at times, our drives may be used in system workloads far exceeding their intended uses. Additionally, some of you have recently shared that in certain, more data intensive, continuous read/write use cases, the WD Red HDD-powered NAS systems are not performing as you would expect.
If you are encountering performance that is not what you expected, please consider our products designed for intensive workloads. These may include our WD Red Pro or WD Gold drives, or perhaps an Ultrastar drive. Our customer care team is ready to help and can also determine which product might be best for you.
Also they published yesterday table of SMR/CMR drives
Note that SMR is bad for video editing, especially if you are trasferring large amounf of files and fo do constantly (with deletion of old ones).
gonna buy several extra drives for my home zfs storage. Soon it would be difficult to find good one(CRM)
Western Digital reportedly is raising its prices for enterprise-use HDDs to reflect increased costs from production and logistics with mainstream products expected to see more than 10% increases, according to sources from the upstream supply chain.
Really? May be this guys just need more money for their nice life?
Toshiba uses SMR technology – previously undocumented – in several desktop drives and in some video surveillance HDDs: P300 6TB, P300 4TB, DT02 6TB, DT02 4TB, DT02-V 6TB and DT02-V 4TB.
Certain notebook PC, game consoles, and external consumer drives also use SMR: L200 2TB, L200 1TB, MQ04 2TB and MQ04 1TB.
Official response.
List of known SMR drives
From https://www.ixsystems.com/community/resources/list-of-known-smr-drives.141/
Hattis Law has filed a lawsuit against Western Digital Corporation alleging that Western Digital secretly switched many of its hard drives, including its WD Red NAS hard drives, to inferior shingled magnetic recording (SMR) technology, deceiving and harming consumers.
I used to like WD but it seems they aren't what they used to be. What manufacturer would you recommend for HDDs in 2020? My workstation drives are nearly 5 years old now and I've been wanting to replace them.
I think all manufacturers are the same (a**holes) - so you have to look for a specific drive.
I can recommend: WD HC510 10TB - low noise, high speed (still close to 200MB/s sustained write at 95% full capacity) and not expensive as "WD recertified" für arround 200 EUR. Similar to WD He10 8/10 TB (see HDD deals).
So, having a blacklist/whitelist of HDDs is the only way to protect you from been screwed (see Vitaliys list above).
As far as I understand HGST is quite good.
WD now use this to sell you older drives under Red Plus name
It is very "easy" to identify WD SMR HDD, assuming the cache size of a disk below 8TB is of 64MB (128MB for Seagate).
Btw, any disk with cache of 256MB (required by SMR techno) of a HDD up to 6TB is a SMR one ...
To identify cache size, the use of WD HDD decryptor is usefull ...
In summary: any HDD with model ID WDxxxxAx up to 6TB is a SMR ... eg. WD60EDAZ, WD30EFAX etc. the "A" is: 5400rpm 256MB cache ...
Not relevant for HDD from 8TB as requesting 256 MB cache on CMR ...
WD decryptor joined ... [Update: WD reassign the F speed/cache code]
R.LAB video on SMR disks (can use google autotranslated subtitles)
