Good design: EK-Loop Connect Controller
    • 1x (PWR) 4-Pin Female Molex (this is only bad in it)
    • 6x (F1-F6) Standard 4-pin PWM Fan Header
    • 6x (L1-L6) D-RGB Header 3-Pin 5V Digital LED Header (Pinout: +5V, D, Blocked, Ground)
    • 3x (T1-T3) Temperature Probe Headers
    • 1x (FLO) Flow Meter Connection
    • 1x (LVL) Coolant Level Indicator
    • 1x USB 2.0 Data Header
    • 1x (EXT) Data Header for Daisy Chain
    • Power Output for Fans: 20W per header
    • Power Output for LEDs: 8W per header
    • 55 EUR
    Software can do
    • Fan Speed PWM Curve Control
    • PUMP Speed PWM Curve Control
    • Addressable D-RGB Lighting Control
    • Physical Thermal-Probe Readouts
    • Hardware Temperature Readouts
    • Manual Air Bleeding Activation
    • Safety Coolant-Level Sensor
    • Coolant Flow Readout
    • Coolant Replacement Reminder
    https://www.ekwb.com/news/keep-your-pc-healthy-with-ek-loop-connect/
  • 1 Reply sorted by
  • Personally used Grid+ V3 ($40 now), software by NZXT becoming better but still far from ideal
    https://www.nzxt.com/product-overview/grid-plus-v3
