Review
https://www.lesnumeriques.com/focales-fixes/nikon-nikkor-z-58mm-f-0-95-s-noct-p53289/test.html
Of course we have also studied AF, and driving the focus lens itself can be done. But the action is quite slow, not as fast as manual operation. At the same time, the increase in size is far beyond imagination. It cannot be driven by the existing ultrasonic motor, and a larger actuator must be arranged outside the lens.
Therefore, if you really want to achieve AF in the f/0.95 lens, this optical type will not work. You need to reduce the focus lens and use the internal focusing method. But using this method will result in a longer overall length, which means that peripheral components will also increase, and the lens will still be larger and heavier than it is now.
Even if such a lens is made, even if the product is very special, it may not be established as a product, so we gave up AF.
Nikon NIKKOR Z 58mm f/0.95 S Noct Lens (Refurbished by Nikon USA), $7499
https://www.bhphotovideo.com/c/product/1597959-REG/nikon_20086b_nikkor_z_58mm_f_0_95.html
