16-35mm F4 S Pro Panasonic Lens
  • 10 Replies sorted by
  • PR
    Panasonic is proud to introduce two new interchangeable lenses based on the L-Mount system for the LUMIX S Series Full-frame Digital Single Lens Mirrorless Cameras. Designed for professional use, the LUMIX S Series offers uncompromising photographic expression with its high-quality cameras and lenses.
    The LUMIX S PRO 70-200mm F2.8 O.I.S. (S-E70200) is a large-aperture telephoto zoom lens that boasts high descriptive performance across the entire zoom range. The LUMIX S PRO 16-35mm F4 (S-R1635) is a versatile wide zoom lens that provides high resolution images and a beautiful bokeh despite its compact, light-weight profile. Both high-performing LUMIX S PRO lenses achieve LEICA's stringent standards.
    LUMIX S PRO/S Lens Lineup as of November 2019
    • LUMIX S PRO 50mm F1.4 (S-X50)
    • [NEW] LUMIX S PRO 16-35mm F4 (S-R1635)
    • LUMIX S PRO 24-70mm F2.8 (S-E2470)
    • LUMIX S 24-105mm F4 MACRO O.I.S. (S-R24105)
    • [NEW] LUMIX S PRO 70-200mm F2.8 O.I.S. (S-E70200)
    • LUMIX S PRO 70-200mm F4 O.I.S. (S-R70200)
    In addition to Panasonic's existing portfolio of first-class lenses for the LUMIX S series family of cameras, the company is committed to designing and developing 11 or more lenses with the emphasis on the "LUMIX S PRO" class by March 2021. Currently, more than 46 interchangeable L-Mount lenses are available or will be available from Panasonic, Leica Camera AG and Sigma, opening up a virtually limitless spectrum of new creative possibilities.
    The LUMIX S PRO 16-35mm F4 (S-R1635) is a versatile wide zoom lens boasts high descriptive performance in both photo shooting and video recording.
    Comprising 12 elements in 9 groups, the use of 3 aspherical lenses, an ED (Extra-low Dispersion) lens and a UHR (Ultra-High Refractive Index) lens and the optimum alignment achieves high MTF performance despite its compact size and light weight. It boasts stunningly high resolution toward the corners even at wide open as well as a beautiful bokeh, suppressing double line bokeh and vignetting.
    A double-magnet linear motor is integrated for the AF actuator, featuring high power despite its small size, achieving a maximum 480 fps high-speed sensor drive. This realizes fast, high-precision AF to ensure that photo opportunities are never missed. Like the 70-200mm F2.8 O.I.S. (S-E70200), the 16-35mm F4 (S-R1635) adopts a focus clutch mechanism, enabling instant AF/MF switching and accurate manual focusing, as well as excels in video recording performance thanks to a mechanism that suppresses focus breathing.
    It is also rugged dust/splash-resistant, *4 withstanding harsh conditions even at 10 degrees below zero for high mobility. The filter size is 77 mm, with a 9-blade circular aperture diaphragm.
    Both lenses will be at retail in January. The LUMIX S PRO 16-35mm F4 will available for $1,499 and the LUMIX S PRO 70-200mm F2.8 is $2,599.
