- Upgraded BIONZ X™ image processing engine gains maximum benefit from the sensor’s fast readout speed. Processor works with front-end LSI to enhance speed in AF/AE detection, image processing, face detection and accuracy, and more
- Upgraded dust and moisture resistant[xviii] design to meet the needs of professionals in even the most challenging outdoor conditions. Stronger sealing provided at all body seams as well as the battery compartment cover and media slot
- Latest image-processing algorithm reduces noise in the medium-to-high sensitivity range while improving subjective resolution and image quality
- 5-axis optical in-body image stabilisation system that provides a shutter speed advantage of 5.5 steps[xix]
- Improved grip configuration for even greater comfort and sure hold. Compatible with Sony VG-C4EM Vertical Grip
- Improved button design and feel. Increased diameter and feedback of the ‘AF-ON’ button; a refined multi-selector joystick design; an exposure compensation dial lock button and a redesigned shape and new position for the rear dial
- Redesigned shutter mechanism to suppress even the slightest movement that can cause image blur. Tested for durability in excess of 500,000 shutter cycles[xx]
- USB Type-C™ connector that supports fast USB 3.2 Gen 1 data transfer
- Dual media slots that are both compatible with UHS-I and UHS-II SD cards, allowing higher overall capacity and faster read/write speeds
- Digital audio interface has been added to the camera’s Multi Interface Shoe™ (MI Shoe) enabling the new ECM-B1M Shotgun Microphone or XLR-K3M XLR Adaptor Kit to be connected directly to the MI Shoe for cleaner, clearer audio recordings
- $4499 at
- Product page - https://www.sony.co.uk/electronics/interchangeable-lens-cameras/ilce-9m2
Samples
https://www.dpreview.com/sample-galleries/7395303261/sony-alpha-a9-ii-sample-gallery/1027861221
New firmware v1.01
https://www.sony.co.uk/electronics/support/e-mount-body-ilce-9-series/ilce-9m2/downloads
@davedv Sony praised themselves with better low light and improved image quality in the press release of the A9II. I want to see something concrete, is that much to ask!?
It's funny how there are virtually no full size sample images from the A9II on the web, although the camera is in the stores already. :)
Considering that it's the same sensor as in the original A9, the image quality should be pretty much the same, especially if shooting RAW. So you could probably look at A9 sample images to get an idea of what to expect.
Yawn@ All camera's lacking 4K 60p or better in 2019. No appropriate words@ how I feel about all of these overpriced non revolutionary "revolutionary" camera's in 2019. "Revolutionary" is the word of the year for marketing apparently. X-T3, and EMX-1 are the only camera's that broke free from the herd, but even they are overpriced. The bubble was popping in slow motion this time, but it has officially popped and these companies will be doused to dull flames if they don't get a clue very very soon.
Main updates since original A9
Shutter unit
Sealing scheme
