Steinberg WaveLab 10
    • Video playback support to arrange, edit and process the audio of a video file in synchronization with the visuals.
    • Extended external effects support for integrating external effect devices into the WaveLab signal flow via external FX buses (Pro only).
    • Reference Track for adding a reference audio file to the Audio Montage, allowing switching between it and the audio files being worked on (Pro only).
    • External editor support for integrating other audio editors into the WaveLab workflow, allowing clips to be modified in those applications from within the WaveLab session (Pro only).
    • Undo/Redo History is a completely new undo/redo edit history system, also now available for the first time in the Audio Editor workspace.
    • Multitrack recording in the Audio Montage (Pro only).
    • Audio Montage Inspector and track list overhaul which delivers user interface improvements in the Audio Montage window, with dedicated controls for audio, reference and video tracks.
    • Audio Montage Inline Editing allows complete clips to be opened from within the Audio Montage and non-destructively edited in the Waveform Editor or Spectrum Editor (Pro only).
    • Live input stream recording which lets as many audio streams as the input device/system can handle be recorded/rendered through the Master section and inserted plug-in chain (Pro only).
  • 2 Replies sorted by
  • New simple version for podcasters and alike - Steinberg WaveLab Cast
