24-70mm F2.8 Panasonic Lumix S Pro Lens
    • 18 elements in 16 groups, 3 aspherical + 1 UHR + 4 ED elements
    • 11 diaphragm blades
    • Weather sealed
    • 0.37m min focusing distance
    • 91mm x 140mm
    • 82 mm filters
    • Comes with hood
    • 935 g
    • $2199.99, availability in October
    PR
    Panasonic is proud to introduce a new interchangeable standard zoom lens, the LUMIX S PRO 24-70mm F2.8 (S-E2470) compatible with the L-Mount system for the LUMIX S Series Full-frame Digital Single Lens Mirrorless Camera. Developed with high-quality professional performance in mind, the LUMIX S Series of cameras and lenses together achieve uncompromised photographic expression..
    The LUMIX S PRO 24-70mm F2.8 (S-E2470) is a large-aperture standard zoom lens that boasts high descriptive performance across the entire zoom range. Optical performance is remarkably high, passing stringent LEICA standards.
    The rugged dust- and splash-resistant* design withstands harsh conditions and ensures versatile use for landscapes, snaps and portraits with its 24-70mm focal length. The LUMIX S PRO 24-70mm F2.8 features stunningly high resolution and high contrast at each focal length point, with a filter diameter of 82 mm and an 11-blade circular aperture diaphragm. The full-range F2.8 high-speed aperture provides smooth defocus gradation from the focus peak to the neighboring area of the image to achieve a beautiful bokeh effect as well as a rich perspective.
    Comprised of 18 lenses in 16 groups, three aspherical lenses and four ED (Extra-low Dispersion) lenses effectively suppresses both axial chromatic aberration and chromatic aberration of magnification. The aspherical shape of the lenses corrects astigmatism, achieving high resolving performance. Furthermore, a UHR (Ultra-High Refractive Index) lens achieves uniform image quality from the center to the edges of the image while downsizing the lens unit.
    A double focus system combining linear and stepping motors achieves sensor drive at a maximum speed of 480 fps. This realizes fast, high-precision AF, ensuring the user never misses a photo opportunity. Focus clutch mechanism adoption enables instant AF/MF switching and accurate manual focusing. The LUMIX S PRO 24-70mm F2.8 also excels in video recording performance with a mechanism that suppresses focus breathing, a common problem in all interchangeable lenses designed for still image photography.
    By 2020, Panasonic will design and develop 10 or more Lumix S Pro and other lenses, further expanding the S Series lens lineup. More than 45 interchangeable L-Mount lenses are or will be available from Panasonic, Leica Camera AG and Sigma, demonstrating an almost limitless spectrum of new creative possibilities.
    The LUMIX S PRO 24-70mm lens will be available in October for $2199.99.
    *Dust and Splash Resistant does not guarantee that damage will not occur if this lens is subjected to direct contact with dust and water.
  • 9 Replies sorted by
    800 x 528 - 41K
    800 x 531 - 73K
