XIAOMI Wowstick Portable Electric Screwdriverfor $28,3
Use $3/30 coupon from above.
Personally have same, use for various things together with manual screwdrivers.
I wish bits storage will be not so nice looking, but more handy :-)
Otherwise have almost all bits you will need in life.
Very nice present also.
Ok. Mi pad 4 is also in India. I'll look for it here. Less issues with customs
Next coupons round
General
New users
AMD Ryzen 5 1600 6 core CPU, $72,9 with coupons
Very nice option.
Netac 720GB SSD for $45,80 only
Use any of $7/60 coupons from above, some may not work already.
https://www.aliexpress.com/item/32982346173.html
SAMSUNG SSD 860 EVO 500Gb for $62,17
Fast M.2 PCIe SSDs
Have pair of such SSDs used for some additional video storage, work nice and fast.
Working coupons
General
FeiyuTech G6 Plus 3-Axis G6P Handheld Gimbal for very good price
Use $5 seller discount, and $15/150 or $10/100 coupons in topic above.
Working coupons codes
Russian
General
Small tip
In Aliexpress smartphone app you can exchange 200 coins into $2/$10 coupon or 1000 coins into $10/$69.
New codes
For new users
Very fast SATA controller with 5 ports
https://www.aliexpress.com/item/33017391503.html
Now price is $20,34-$2 select coupon-$3 general coupon
FeiyuTech Vimble 2 Smartphone Gimbal for $68
Use $7/50 coupons, $2 select coupons, $2 seller coupon.
ZHIYUN Official Smooth 4 below $100
Use $2 seller coupon.
And add to this $5-7 coupons from topic.
Top DAC/Preamp
Very good product made by good engineers.
$6/65 select coupons work, and $10-15 coupons from this topic above.
https://www.aliexpress.com/item/32956563439.html
Some measurements can be checked at https://www.personal-view.com/talks/discussion/20885/topping-dx3-pro-dac-and-headhone-amp-recommend/p1
eVtran really fast flash drive
It is still one of very few options for very fast and steady write speed super portable drives.
As it is effectively SATA MLC drive with fast USB bridge inside little flash drive case.
Use any suitable general coupons from this topic.
https://www.aliexpress.com/item/32977697862.html?storeId=2842018
Very good sunhood for GH cameras
SmallRig Cages - best quality among affordable Chinese made cages
Thanks! Bought few items. Hope they'll be good.
New aliexpress codes
Two high CRI panels set with stands
Deal for US and Russia.
Get $3 seller coupon.
And also use $5-7 coupons above in topic or 10/100 coupon.
Famous Scythe Gentle Typhoon fan
Uses Nidec motor.
It won many tests beating famous Noctua fans. No longer made du to high costs, so it is remaining stock.
You will pass it in working state to your children.
If you get multiple of them can use sellers coupons discount.
Use any general coupons that work over $25 sum.
Very good Godox led panel with nice discount
Use $1 seller coupon and $5-$7 coupons above in this topic.
Padded tripod/stands bag
Use $3/20 coupon or similar.
