Panasonic AG-CX350 4K Camcorder with 4Kp60 10bit HEVC
  • 30 Replies sorted by
  • Firmware Upgrade Ver. 2.01 for AG-CX350 brings key new features
    New Features
    1. New 4K codec and conventional P2HD format recording are supported.
      1. HEVC LongGOP 100M (MOV)
      2. P2HD AVC-ULTRA(P2 MXF) Intra422, LongG(AG-CX200MC does not support HEVC LongGOP100M, P2 MXF and AVC-ULTRA codec.)
    2. 4ch audio recording is supported when you use MOV or P2 MXF formats.
    3. Multicast is supported when you use RTSP streaming or NDI|HX networks.You can use multiple ports (PC, switcher or application software) to receive a single streaming that is distributed by a camera.
    4. You can use CX ROP application software and NDI|HX simultaneously.
    5. ADAPTIVE MATRIX menu is added.You set this menu to "ON" so that the color is not saturated with strong blue LED.
    6. The function is improved at operating a USER SW so that a message is displayed at changing the settings. For example, you can see that the setting of LCD VF is changed from SDR to HDR.
    7. (AJ-UPX360MC and AG-CX200MC only)\ The initial value of the scene file menu is changed to "SPARK" as in AJ-PX298MC. To enable this setting, you need to initialize the menu after the update.
    Improvement
    1. There is a problem that a center position mark is not strictly center of VF image when you use an expanded view of focus assist function. This problem is fixed.
    2. There is a problem that DRS ON setting is not reflected on when you change the LCD monitor image from the thumbnails to the camera image. This problem is fixed.
    3. The zoom function may not work if you rotate the zoom ring frequently and press the zoom button again and again. This problem is fixed.
    4. Quality of image with low bit rate IP streaming is improved.
    5. Quality of audio with RTSP/RTMP streaming is improved.
    https://eww.pass.panasonic.co.jp/pro-av/support/content/download/EN/ep2main/soft/upgcx350_e.htm
