PS5 dev kit specs
Some leak of Xbox specs
Scarlett Devkit ( Dante ) Preview.1
- Rev.1 Production in Oct 2019.
- Final version around Aug 2020.
- Preview.1 built-in Chuckwalla case.
- SOC: Anubis ( 393mm2 )
- CPU: Custom Zen 2, 8 Cores 16 Threads @ 3.4GHz Built-in with DirectX 12.X, DXR, DirectML and Havok instructions into the chip.
- GPU: Custom Navi 21, Full 56 Compute Units @ 1623MHz
- RT: 1 RTC per Compute Unit
- RAM: 48GB GDDR6 @ 560GB/s
- STORAGE: 1TB+4TB SSD NVMe PCIe 4.0 @ 4GB/s, Flexible Dedicated vRAM starts with 32GB ( Up-to 64GB )
- AUDIO: Custom Tensilica HIFI DSP
- I/O: 2x HDMI 2.1, 4x USB-C ( Thunderbolt ), 2x USB-A, 2x RJ-45, 1x S-PDIF, 1x IR-OUT, Bluetooth 5.0, WIFI * Direct, WIFI IEEE 802.11ax
- API: DirectX 12.X, DXR, DirectML
- PSU: 275W
Scarlett ( Retail )
- Targeting Performance.
- GPU: Custom Navi 21, 52 Compute Units @ 1623MHz
- RAM: 24GB GDDR6 @ 560GB/s ( Samsung 12x2GB ), 18GB GDDR6 + 2GB GDDR6 Cache + 32GB~64GB SSD vRAM ( Up-to 84GB for Game ) and Dedicated 4GB GDDR6 for OS ( Native 4K60/120FPS Dashboard )
- STORAGE: 1TB SSD NVMe PCIe 4.0 @ 4GB/s, Flexible Dedicated vRAM starts with 32GB ( Up-to 64GB )
- I/O: 2x HDMI 2.1, 2x USB-C ( Thunderbolt ), 2x USB-A, 1x RJ-45, 1x S-PDIF, 1x IR-OUT, Bluetooth 5.0, WIFI Direct, WIFI IEEE 802.11ax
- PSU: 275W
So, as we can see - it will be quite weak. SSD most probably will be QLC to maximally save on costs.
4GB now required for dashboard and stuff, huh. Quality of modern developers.
At peak it will consume 250 Watts and it is extremely low, as same 3700X overclocked consumes around 150 Watts, same is true for graphical system. Most probably here we will see first time same approach with notebooks - software will throttle things and all real performance will be restricted by thermal package and not real hardware limits.
Xbox Project Scarlett, release in Holiday 2020
From the start consoles will be extremely underpowered compared to most good PCs, only advantage will be more RAM available for GPU. So if you intend to play new games look no less than 11GB for your next GPU and it'll be ok.
