If one above does not work use ALIRUMODA4, ALIRUMODA5, ALIRUMODA6 and so on.
From tomorrow - $5/20 coupon
$56 for real 512GB TLC NVMe PCIe x4 SSD
Use $5/35 coupon also.
SSD is based on SM2263XT, quite good and fast controller that uses system RAM to translation table (hence cheaper than DRAM based SM2262), for large stuff like video files performance is almost same (for large databases it is not).
New DDR4 memory drop where you can use coupons
$15/$120 coupon
You will need to change delivery country to "Saudi Arabia" and return to same coupon page after this :-) After getting coupon can change things back to normal.
