Would someone mind posting the MSU deflicker settings that worked for them ? Specifically for fluoro light in PAL or NTSC with an incorrect shutter speed.
As I remember I´ve had 2 scenes with flickering, and settings from one wasn´t good enought for the second.. from the 3 sliders I only remeber that I´ve had safety at the lowest number, and change ground/blend treshold were from middle till end, I´ve had to play a lot with these two to get something that is acceptable for me
when I started testing the settings I´ve divided each of the sliders to 3 parts  (left, middle,right)  and tried all of the combinations until I saw what looks the best, then I tried to fine tune the settings in  the range that looked the best for me..
If you don´t get results you are expecting from virtualdub try GBDeflicker, you never know
