Will be putting useful things only, not much.
Some breakdown on Aliexpress 11.11
It also means that during sale cheapest item is not one where you see cheapest price :-).
$5/35 coupons and select coupons
Plus many Chinese sellers use old trick with price using algorithm hole. They make some cheap option and mark it later as unavailable.
What is JoyBay?
So, small conclusion, looking at prices/coupons changes after event.
All posted deals had been real, good deals. Some where designed to apply different 11.11 coupons, as told.
It had been many members who used this deals, hope they'll like stuff as it'll come.
Sandisk Extreme Pro card readers
Very good fast readers - USB-C and normal USB port types. USB-C for Mac users.
Xiaomi 3 in 1 mijia Smart Home, integrates with lamps and more, $31,95
Personally recommend - one of the best and simples smart home solutions.
Includes usage of $5/35 coupon.
Very fast portable 256GB flash drive, $42,75
Price includes $5/$35 coupon and also $1 seller coupon.
Samsung EVO card with good write speed for $18.8
Wow! Lot of useful things. Need to check if have funds for eVtran26s flash drive.
My usual table lamp - Xiaomi Philips Smart Lamp
High CRI, handy adjustments, integrates into Xiaomi smart home.
Has handy separate light to light up background.
eVtran26s 128gb High Speed Flash Drive MLC - 320Gb/write, $43
Price in title includes $5/35 coupon you can get in mobile app playing simple thing.
This company is quite unique as they make their own super speed drives not on usual USB flash controllers. Each such drive is USB 3.0-SATA 3 fast bridge, after this good SATA SSD controller and multichannel MLC chips.
EAGET Y200 2.5-inch 1TB HDD with Smartphone Network Backup, $65
You can connect it to any router by wire and locally/remotely backup your videos/photos from mobile to it (as well as access it).
Price includes deducted $5 new registered user coupon.
120cm motorized slider with smartphone control for $259
Note - price in title includes select coupons applied (see top post in topic!).
If you'll also use $5/25 coupon it'll be even lower.
Thanks! Plan to get small light and usb lav later today.
Aputure Amaran MX for $134
Best small portable light for now!
Aputure Amaran AL-F7 for $83, $79 if get two (normal price around $99)
Note - if you get two, due to select coupons price will be lower (remember to collect this $2 coupons!)
BOYA BY-WFM12 Wireless VHF Microphone for $81,24
Make sure to get $3 seller coupon to get title price.
It is newer Boya entry wireless system, as far as I know it is really reliable thing, not high end, but works good.
Godox 60W LED Light for $109
Personal recommendation, you can check our big topic on it - https://www.personal-view.com/talks/discussion/17664/cheap-powerful-godox-sl60w-led-fresnel-below-199#Item_70
Make sure to add any other small item to $130 total (any other seller, with support of $6 from $65), and price will be as in title. Make sure to collect select coupons.
Rapoo MT750 wireless laser mouse for $22,5
Recommend this thing. Very good quality and switches are better than top Logitech.
Remember also Cheap Color Chart
Cheapest Aputure M9 alternative (CRI also high!) for $16.5
EDIFIER S1000DB - superb monitor speakers, $233 after all coupons
Remember about seller coupons and select coupons!
Nice starter 4 core Ryzen processor - around $69 after coupons
Full Windows PC with 10-12bit decoders for $124
More portable variant with better RAM/SSD, price with coupons close to $175
Good USB lavaliere mike with headphone output
Especially good for latest Mac notes users. Heard really good feedback about it.
FX-AUDIO DAC-X6 MINI DAC With Headphone Amp
Very nice item, if you do lot of editing, but do not do music/speech recording or such (that require audio XLR interface). Good quality and very fast volume adjustment.
Comica microphone
Looking at the specs and direction diagram (see below) you can use it just as light super cardioid mike for inside jobs with build in shock mount and foam screen.
Saramonic UWMIC9 System
Note that price here is not $360, you need to deduct $6*5 select coupons, fixed coupon and seller coupon.
