@Driftwood ... is it possible to make a patch with lower bitrate for 24p but keep GOP1 (all others the same) ? I don't have a big card, and would like to save some space.
@HillTop1 Welcome! ;-) "What's the bitrate at 24H and 720p60 then?" I think that it will be about 60-70M usually as a matter of fact although 24H is set as 176M. In 720p, I have adopted the arrangement of Chris as it is, and since I am not using 720p at all, I do not know.
I have a big question about these patches. Remember, few month ago, some of us have encountered an issue with their 66mbps hack : Camera crashed when the .mts hit 4GB. At this time, we thought that the card speed limits was the problem. I have tested 2 rates at 166mbps and 50mbps, with the AQuarius 2 patch. (Other Values remain the same). Camera Crash after 4GB, both in 50mbps and 166mbps (even if the bitrate was under 50mbps in the second case). I use a SanDisk Extreme Pro 45MBps, so, write speed should not be a problem. So, do you think this problem is due to the video buffer or something else ?
@bkmcwd great thanks, will check it as soon as I get home. What's the bitrate at 24H and 720p60 then?
@driftwood looking forward to test out SeAQuake as soon as I get home. I think I will start bringing my GH2 to work lol. I love your nomenclature of your patches lol. What's the bitrate at 720p60? On a separate note, how's your collaboration project coming? Dying to see the finished product.
@FGCU 166M for H. Its primed to the buffer fullness, dont need 176M, you can raise the bitrate higher if you like to no advantage - the i frames won't get any bigger.
The economy patch of Q18 was renewed. Although the bit rate exceeds 100M under high stress, I think that this becomes the about an average of 60M bit rate usually. With this patch, since frame size is not compressed even if moving a camera up and down in woods, I think that I will give the name in connection with woods or forest. It is the same as usual the arrangement of Chris except 24p.
@HillTop1 I am sorry that I did not reply to you sooner. Since 88M patch is not so good, try this instead! I stick my done patches on "GH2 Patch Vault, most popular patches in one place" thread. :-)
How we make 50i PSF material to show in NLE (i use FCPX) like 25p ? I want to make a video with footage from my nex 5n (25p) and GH2 (50i psf). when i put my gh2 footage in the same timeline with original 25p , it show me that it needs render....
@Driftwood Looking closer at your chart, I see it quickly drop from the h rate to the l rate, which is where I want it to be. Why should I care about those early frames when they do not appear to cause any practical interference? What should I be worried about? Thanks
@driftwood Every test has been rock solid. How should I expect the buffer under run to manifest. VK mentioned that 3.63 allows very low 24l bitrates. Could that be why this is working for me?
@Driftwood Thank you very much for your new patch release. For me, the great news is the ability to get 25 P via PsF. My doubt is about the workflow to get this. Any idea?
@driftwood filmed a video installation with the last intra, super image! Even at 720. Would have loved to send it into the collaborative project.... Will post a few scenes...
PS: Lens 35mm Samyang 1.4 PSS: Image not original 720p - sorry- will repost when I have file at hand :-(
