Lilliput A7S FullHD IPS On-Camera monitor
  • 14 Replies sorted by
  • Internals (5:50 start)
  • @Grimor
    Can make short demo, explain how to reproduce and send them email.
  • I found a bug trying to de-squeeze anamorphic 4:3 footage from Gh5 with A7s. When i set the aspect ratio to 2.35:1 on the monitor image became glitch like, with weird lines across the frame. If original signal is 16:9 then the 2.35:1 aspect squeeze without issues. Any tips or workarounds?
  • I just got an A7s, my first field monitor, but I like it so far. It feels well made and is easy to set up. Took some time to adjust the color settings. Vitaliy is right about the blue channel. Here is what I ended up with adjusting the 'user temperature' by eye (attached to a macbook using 'HD 709-A' color for both monitors): Red Gain +122 Green Gain +126 Blue Gain +138
  • Under "Custom Temperature" i can set Offset & Gain of each RGB channel. What will be a more accurate custom setting?
    It depends on specific monitor. You can just connect to computer, find any place with grayscale generator and adjust by eye.
  • @Grimor
    Default white setting is not ideal, need to adjust B channel. If you look at Gamut CIE Chart you will see that adding slight amount of Blue prime to other channels is also good.
    Gamma curves
    RGB levels
    800 x 359 - 43K
    800 x 358 - 37K
  • What does the lower red wave at white colour spectrum mean? Is this monitor color accurate?
  • PV Lab Report: White Color Spectrum, sRGB Mode
    PV Lab Report: Blue Prime Color Spectrum, sRGB Mode
    PV Lab Report: Green Prime Color Spectrum, sRGB Mode
    PV Lab Report: Red Prime Color Spectrum, sRGB Mode
    800 x 287 - 61K
    800 x 287 - 54K
    800 x 286 - 56K
    800 x 286 - 47K
  • PV Lab Report: sRGB/Rec 709 mode color gamut
    800 x 697 - 82K
  • PV Lab Report: DC Consumption Test at typical easy mode - FHD 30fps, Peaking
    Cutoff voltage - around 4.60v (as voltage drop below this value monitor will turn off or blink or such).
    Standby consumption - around 2,1 watts, very high! Make sure to remove battery!
    800 x 481 - 67K
  • Really affordable. But why they made bumper in such colors?
