Powering GH2
  • 381 Replies sorted by
  • Also, there is a problem to find genuine DC-coupler for GH2.
    Any tips where to buy it in Europe ...
  • @Alfi666
    What is the model, type of battery indicator ?
  • @5thwall Thanks for the info! Missed the sale but still curious about the battery. Maybe you can share your thoughts once you've spent some time with it on your rig...
  • @griplimited
    OK, you need to have some basic electrotechnical skills, soldering iron and a voltage meter.
    You need a battery holder for NP-F970 - it can be one of those cheap chargers sold on ebay (about 5-6$)
    Dismantle the charger and remove all electronics - leave only the contacts for battery.
    Order a "LM2577 DC-DC step up converter" from eBay. Then you can put this converter in the charger.
    Onto the input pins of DC-DC converter connect the battery (take care about + and -)
    Now with the voltage meter connected to output pins on DC-DC board, set the correct voltage with the blue potentiometer.
    You can set it to about 9V - that's working fine for me.
    Now just find some cable and connect the output from DC-DC board with the DC coupler that you already have.
    That's all.
    Only problem is, that you have no idea on status of the battery - so to improve the design, you can order also an "RC battery voltage indicator" on eBay and connect it with some switch to the input part of the DC-DC board. When you press the switch - the indicator will show you the current battery voltage. The battery is OK until it is over 7.0V
  • @Alfi666
    Please do provide the details.
    I own a third party coupler with AC adaptor, same that evero posted.
    I also own two 970 batteries. This would complete me.
    Thanks in advance.
  • I'm powering tmy GH2 with DC coupler (made from 3rd party battery) and with Sony NP-F970 battery. There is a DC-DC booster which brings up the 7.2V of Sony battery to 9V for GH2.
    GH2 can run for hours with this setup (already tried 8hrs but battery was still alive).
    If anyone interested, I can provide more details
  • @SisterCities Also, keep in mind if you are interested in the Jag Battery that they have a 20% off sale for Cyber Monday which is tomorrow. Wish I'd waited so I could've saved some $$$! ;D
  • @SisterCities I haven't had a chance to really run it through it's paces. I'm going take it out this week. Initial thoughts - solid build quality, good customer service, and plenty of screw holes that you can attach a rail block to for fitting on rails. One thing I'm a little concerned about is the power cables getting pulled out from the side, but a little gaffers tape should fix that right up.
  • @redpaw Could you or your friend provide us with info about the circuit you have built into the V-mount adatper? I have some ideas, but it would be nice to know about a proven solution.
  • @5thwall Any update on the GH2 Power Adapter by JAG35?
    Can anyone else comment on this unit?
  • For reasons of simplicity and compatibility I decided to go the V-mount route. Does anybody know a reseller of good cheap V-Mount batteries around 130Wh in europe?
  • Guys we have been over this surly its been done :-)
  • @fatpig As I said in my post, I felt the one downside was price. However, it's a guaranteed, warrantied, and tested solution that will fit on my rig easily. Also, It's built by a local southern California vendor and I want to support their company. For me, there's a lot of value in that.
  • Picture with GH1 only, u have to specify GH1 or GH2 for the coupler if u buy from them.
  • @7hau
    Interesting. Although the sample pics of his alleged GH2 battery grip doesn't actually picture a GH2... Is it a GH1? I dunno
  • @5thwall: Dont you think that 350$ is a little too much for something you could easily build yourself for about 50 bucks? Using the dc coupler and some chinese 9v 9800mah battery off ebay?
  • Jag35 just launched a battery adapter for the GH2 that works with their branded battery. I visited their office a couple weeks ago. I really like what they're doing and I think the quality of their stuff is pretty darned good. Haven't tried the battery out yet, but I'll be purchasing it online tonight and will let you all know how it works. Supposedly the basic battery will last a day or two with the camera. The battery isn't removable so, you'd need a backup source when it drains - another Jag35 battery or good ol' panasonic batteries. Still, I like that it's an all-in-one solution and can be adapted to fit on rails with rail blocks. The downside, in my opinion, is that it's more expensive than some of the alternatives on this page.
    Battery adapter: http://jag35.com/gh2poweradapter.html
    Battery: http://jag35.com/products/power/jagbattery.html
  • These are quite cheep in Australia:
    http://ritmotech.com.au/onlineshop/product_info.php?cPath=21_38&products_id=320
    (Sorry for horrid photo- it is Ritmo btw...)
    This will need a converter from 19v to 9v (available at a shop called Jcar here)
    All up $130 aud.
    (now only if I can decide between Juice Pedal and this...)
    438 x 411 - 61K
  • @DslrDan You mean the coupler? eBay.
  • @ed_lee83 Cool setup, CPM tools has some quality stuff! Where'd you get the adapter for the gh2?
  • I use the Tekkeon battery + original DC coupler with CPM's custom rail mount attachment. Here, I also use it as a light counter-weight on my rig.
    While hand-holding I can just slip the battery into a pouch - it's not as 'clunky' as V-mount or Sony type battery solutions.
    Costs only $200: Here's the link http://www.cpmcamerarigs.com/Tekkeon_Battery_Mount_p/092_mp3450i.htm
    1600 x 1200 - 584K
  • @PerryWilson do you have any pics of your setup with the vagabond?? thanks!
  • on a tripod I just let it hang... with the battery around my shoulder using the shoulder strap it comes with... but all that will change once I have my cage finished :)
  • @evero I am using the AC adapter, its lightweight and the converter box on the adapter isnt that big.... on my shoulder mount I just zip tie it up
