Wide lens with easy starbust effect under U$500?
  • Nokton have an amazing facility to achieve this effect with stunning clarity and from a low opening F2.5, the problem here is the price, these lenses are around $1,000. Does anyone have any idea if there will be a wide angle with similar effect and is accessible to work on night images?
    I have read that this effect is achieved with optics with a number of odd knives. But not all have such a level, with my PanaLeica 25mm 1.4 I need to close to F7+ with what I have less light input and feel the difference.
    Thanks.
  • 10 Replies sorted by
  • @Manu4Vendetta
    I think need to look for older lenses. Yes, odd number of diaphragm blades and non rounded blades.
  • Have a look a star filters.
  • @Psyco
    Including software ones.
    Also more radical option is to get cheap manual lens and remove aperture replacing it with star shaped fixed aperture. Not so hard.
  • @Vitaliy_Kiselev, Ok, but what lens?
    @Psyco, I have thinked in that option, but can be a look more artificial.
  • @Manu4Vendetta
    Any good suitable lens. Can even use new Chinese cheap lenses.
  • Thank you @Vitaliy_Kiselev, I see that most are very expensive optics Leica and Zeiss. The effect from the Samyang dond convince me, I see it lack of character and at a level far below (not as a lens, but in that effect). My Panasonic 14 2.5 give me that like Samyang.
    The rest (CaNikon) I see that most are telephoto.
    Look like the only angular that gives this effect with both character and low apertura is the Nokton. :(
  • A lot of the old manual focus AIS Nikkor primes do a star filter effect...
    I have a few images on Flickr that demonstrate this and most will have lens and camera settings listed below the image...see here
    flickr.com/photos/spectrapix
    The examples below have this effect...the bottom image was shot using a Tokina 12 -24 which is wide enough on micro four thirds using a metabones adapter.
    1000 x 614 - 360K
    1020 x 720 - 762K
  • Tokina 11-16 mk1 does this.
    971 x 522 - 554K
  • Lensbaby Sweet
    794 x 527 - 87K
    475 x 355 - 28K
    549 x 563 - 54K
