Nope.
If NLE is made properly even Core i5-8600K will be much faster due to QuickSync.
I mean here real NLE usage, not most benchmarks made of complex 3D transitions, CPU only filters and such.
You know, I never tried a non-hyperthreaded processor. I think I can use Quick Sync on Premiere if I also get the TMPGEnc plugin, I will try it out and see how the quality is.
That Intel chip looks juicy, but I would need a new MB as well.
Proper NLE with usual usage must offload all decoding and encoding to proper hardware (QuickSync or Nvidia GPUs). With all transitions and filters being done 90% on GPUs (10% is CPU due to transfers and such).
Almost all NLEs are designed for stone age still with huge inertia and old code. It is good reason why it is such, as developers qualification required for old approach is much lower.
i5-8400 Benchmarks and Comparison
I'm trying out the Intel renderer but so far the results look more like preview material--still useful.
https://www.pugetsystems.com/labs/articles/Premiere-Pro-CC-2017-1-2-CPU-Performance-Core-i7-8700K-i5-8600K-i3-8350K-1047/
The Intel renderer looks more blocky--not a big difference, maybe there is a way to optimize it.
https://obsproject.com/forum/threads/comparison-of-x264-nvenc-quicksync-vce.57358/
I think this comparison and whole talks are useless.
As they are for low bitrate modes and encoding of video games (it is fast jerky motion most of the time).
Power of hardware encoder is if you use good bitrates and normal videos (especially like your concerts that are mostly still). With normal bitrate difference with x264 will be really small.
Overclocked results (note - they made replacement of thermal interface between chip and cover!)
Core i5-8600K review
Intel actually can't cope with cooling processor with Turbo mode.
Intel actually ask Z370 board manufacturers to make Turbo mode more light (but they do not want to do it, as benchmarks will get up to 10% penalties)
Check below recommended mode (frequency and VCore drop)
So almost all preliminary benchmarks had been artificially inflated 4-10%.
x264 encoding performance
x265 encoding performance
i5-8400
BF Sales
http://www.microcenter.com/product/486088/Core_i7-8700K_Coffee_Lake_37_GHz_LGA_1151_Boxed_Processor
