NeatVideo 4 denoise presets and profiles for Panasonic Lumix G7, for 4K and Full HD.
Conservative amount of denoise to avoid plastic look and keep image texture after denoise.
Camera settings:
Standard
Sharpness +1 (also works for sharpness 0)
Noise reduction -5
Two versions:
Without shadow/highlight curves
With shadow/highlight curves, S+3/H-3 (the maximum amount before image gets ugly) (can be used also for S+2/H-2)
Download in posts below:
Fine tuned profiles and presets using new footage from denoise target, more calibrated exposure and more accurate settings. Using 1/3 iso increments from 200 up to 2000, the maximum useful iso in G7. Now 4k ISO 1600 looks like ISO 100.
Camera settings: Standard, sharpness +1, noise reduction -5, saturation 0, contrast 0.
SH versions use Shadow +2 / Highlight -2 in camera. ETC = extended tele conversion mode.
Also using less amount of denoise in chroma channels to avoid flat color surfaces in low light and shadow areas.
If you want to use higher isos, 2500 and above, I recomend use camera noise reduction in "0". Instead of using these isos it is better to add light.
New versions with less amount of denoise in chroma channels in an attempt to avoid flat color surfaces in low light and shadow areas.
