Canon EOS 77D DSLR Camera with 18-135mm USM Lens, $799
https://www.bhphotovideo.com/c/product/1318767-REG/canon_1892c002_eos_77d_dslr_camera.html
EOS 77D Body Refurbished, $499
use code HOLIDAY19
https://shop.usa.canon.com/shop/en/catalog/eos-rebel-77d-body-refurbished
Canon EOS 77D DSLR 18-135mm USM Lens + lot of stuff, $1049
EOS 77D Body Refurbished, $599
Refurbished stuff
Review
When shooting movies, the Dual Pixel AF system was quick enough to lock onto most subjects but tended to become confused when new subjects entered the frame from any direction. Lags of up to a second were also common during panning and zooming, particularly in low-contrast lighting and with fast subject movements.
Video quality was similar to the clips we obtained from the EOS 80D, which isn't surprising as this feature has barely changed. The slight differences between Standard and Light (IPB) settings were largely related to their different bit rates. Movies shot with the Light setting were also slightly slower to re-focus and more prone to glitches than those recorded with the Standard setting.
Aside from that, any differences between the HD 1080p and 720p video clips were largely related to the frame resolution and negligible when clips were viewed on a normal HD TV set. Audio quality was similar to that of the EOS 80D we tested. We didn't detect any pick-up of operational noises when zooming and re-focusing while shooting movie clips.
http://photoreview.com.au/reviews/dslr-cameras/entry-level/canon-eos-77d
Review
The camera can record FullHD video at 60, 50, 30, 25 or 24fps, with stereo sound. There's also a microphone socket if you want to use an external microphone. You can use the movie mode in auto or manual modes, and there's a time-lapse movie mode as well. Video quality is quite good, although using the electronic image stabilization results in the frame being cropped, which reduces image quality. Video footage will benefit from the use of a lens with optical image stabilization for the best quality, or the use of a tripod.
https://www.ephotozine.com/article/canon-eos-77d-review-31163/
Review
DSLR video has matured a lot and, especially with Dual Pixel CMOS AF in use, very high grade video quality is now the baseline of what you can expect from an EOS DSLR. The 77D gets the same video capabilities as the EOS 80D with the sole difference being that the .MOV format is only available in time-lapse recording on the 77D, whereas the format is a selectable option for traditional video recording on the 80D.
The 77D records video in .MP4 format (IPB/IPB light) using the MPEG-4 AVC / H.264 codec. As noted, time-lapse movies are recorded in .MOV format (ALL-I). Audio is recorded in AAC (.MP4) via dual front microphones (producing stereo sound) or the 3.5mm stereo input jack; no audio is recorded during Time-lapse Movie capture. Sound recording levels can be set to Auto, Manual (64 levels) or Disabled entirely. Wind Filter and Attenuator options can be set in the sound recording menu.
http://www.the-digital-picture.com/Reviews/Canon-EOS-77D.aspx
Review
Good set with lot of free accessories for $849 at https://www.adorama.com/ica77da.html#source=productOptions
Review
It's not going to be anyone's first choice for high-end cinema shooting, but the EOS 77D will be great for those looking for a vlogging camera or it has the potential to be a good home movie machine for families.
