Looking at benchmarks they must work
128gb
256gb
They have issue with small write chunks, but must not be issue for videos in GH5.
@Vitaliy_Kiselev Those Lexar will not work. They claim a minimum sustained write speed of 30MB/s which multiplied by 8 (to convert from megabytes to megabits) gives us 240Mb/s - not quite 400Mb/s of new firmware. V60 cards just cut it - 60x8=480 and V90 is the safest bet at 90x8=720Mb/s min sustained write speed.
This ones must work
Lexar 128GB Professional 1000x UHS-II SDXC Memory Card (2-Pack, Class 10, UHS Speed Class 3) 2 pack
https://www.bhphotovideo.com/c/product/1090745-REG/lexar_lsd128crbna10002_pro_1000x_uhs_2.html
Apparently, you can output HLG with 4K 60P 10bit over HDMI-- but you need an Atomos recorder to get it, and maybe they'd need to upgrade their firmware to deal with it.
Do not worry so much, as firmware will be out we'll have lot of cards tested by users.
499$ for panny sd claiming to work with the new firmware end of september... and there's no other card available at the moment.
Panasonic GH5 4K VIDEO/6K PHOTO Digital Camera, $1879
RED VS GH5 Camera Test
I found a setting in PC Potplayer which plays my GH5 4k 60P buttery smooth with low (20%) CPU load and 35% GPU load. With default settings my 6 years old computer uses 100% CPU / 5% GPU and the play is choppy. -Vesku
The odd thing is my computer wont play GH4/GH5 4k 30P smoothly with any settings. It always drops some frames. How can it be possible that 4k60P plays better and perfectly?
@Manu4Vendetta I see pretty much the same noise at one stop lower ISO for a sensor 3,8 times smaller. This is an achievement considering the difference in sensor size between the two, if both wold have used the same tech, the GH5 should have been two stops noisier (not one stop). :)
The GH5 is noisier with half exposure.
An interesting RAW image comparison: Panasonic GH5 vs Nikon D850, normalized resolution and NR 0. Pretty impressive results for it's sensor size, won't you say?
Our video about best GH5 cage on the market
can't wait until it pops up in special deals
Shot with the GH5 (Vlog) and Voigtlander 17.5mm:
Found the mirror and the reflection of the GH5 looked amazing, just as Panasonic promised! :-)
Find the mirror nearby and will see :-)
What is the dynamic range of the camera?
