Review
https://www.focus-numerique.com/focale-fixe/tests/nikon-af-s-nikkor-28-mm-f-1-4e-ed-3309.html
Review
Wide-open, the lens is surprisingly sharp in the central region of the frame. Given the wide angle and super-bright aperture, there is some noticeable softness in the corners, which we expected (but it's all fairly reasonable). As the lens is stopped down, the corners become much sharper, peaking at f/5.6, and then being subject to diffraction limiting as the lens is stopped down further.
https://www.personal-view.com/talks/discussion/17056/28mm-f1.4-e-af-s-nikkor-ed-nikon-lens
Wow what performance! Guess it should be expected for a $2000 prime but still...very impressive
Samples
https://www.dpreview.com/samples/1487370851/finishing-the-line-nikon-28mm-f1-4e-ed-sample-gallery
Samples
https://www.ephotozine.com/article/nikon-af-s-nikkor-28mm-f-1-4e-ed-hands-on---sample-photos--31077
PR
AF-S NIKKOR 28mm f/1.4E ED – The Latest in The Gold Ring Series of f/1.4 Primes in the NIKKOR Line
The new AF-S NIKKOR 28mm f/1.4E ED is Gold Ring glass that provides maximum versatility for outstanding definition and sharpness regardless of shooting scenario. With a fast f/1.4 maximum aperture and nine blade rounded diaphragm, it affords a shallow depth of field with gorgeous bokeh and stellar low light performance, making it a great choice for shooting low light landscapes, interiors and events.
The superbly balanced and solid body is composed of lightweight magnesium alloy, and features dust and water drop resistant sealing to withstand the elements, combined with a fluorine coating to resist dirt and smudges. The optical construction of the lens is engineered for the best possible wide-angle image quality. It consists of 14 elements in 11 groups, with three aspherical elements that virtually eliminate coma, aberration and distortion, with two ED glass elements that minimize chromatic aberration. The lens also uses Nikon’s Nano Crystal coat to reduce instances of ghosting and flare.
The new AF-S NIKKOR 28mm f/1.4E ED is a welcome addition to Nikon’s stable of impressive f/1.4 primes that give professional photographers and creators the highest levels of image quality and performance, which also include; The AF-S 24mm f/1.4G ED, AF-S NIKKOR 35mm f/1.4G, AF-S NIKKOR 58mm f/1.4G, AF-S NIKKOR 85mm f/1.4G and AF-S NIKKOR 105mm f/1.4E ED.
