"ETC does work well if you understand it has limitations. Part of what makes DSLR's good in low light even with high ISO is that the images get scaled or binned or reduced in size. Whatever you want to call it the fact is that we are never seeing a 1 to 1 ratio of CMOS pixels to recorded pixels. This helps smooth out the noise.
In ETC mode you actually are using a 1 to 1 pixel ratio so you do not gain any of those size reduction advantages. This doesn't mean ETC is bad. In fact it is no different then a normal single chip video camera. ETC basically acts like a single 1/2" CMOS 1920x1080 chip. On those type of cameras going to 9db or 12db of grain looks pretty bad. Heck some don't even like the look of 6db on some of those camcorders.
So yes ETC can visually have more noise then normal modes but not because it is inferior or a useless feature. It has more noise because it acts as a normal CMOS chip would in a regular video camera. Normal shooting modes on the GH2 just help mask some of that noise so you can push the ISO much higher and it still looks clean. In good lighting ETC is awesome. In moderate lighting ETC is decent. In low light forget about ETC. Of course in that kind of light good luck finding a tele lens fast enough anyway. If it really does get that dark your options get very limited if you still need to reach far. Just the way it is.
So you can buy a camera without ETC mode but then you have no option at all. At least with the GH2 and GH3 the option is there if you need the extra reach. If you do the kind of shooting where you want to shoot like a video camera then really you should buy a video camera. A DSLR can look awesome but it is not a 100% replacement for event work unless you want to work around the limitations. "
Thomas Smet in http://www.dvinfo.net/forum/panasonic-lumix-gf-gh-series/511979-gh3-does-have-various-crop-modes.html#post1763106
Just sharing.
Hi,
For high contrast dramatic scenes, unacceptable to me, but I've seen other GH2 footage and it was like mine, so I think it's just bad QC on Panasonic's part... hit or miss maybe.
From the many threads I've read (maybe hundreds) noise at ISO 160 is a common problem. I guess it is a subjective measure of what you can tolerate.
If my camera is faulty, well I'm stuck with it, but I was hoping that Panasonic, or some Hacker would improve the performance, especially in ETC Mode.
Post-mortem:
After all of my research I decided I had enough information to make hacking my GH2 worth a try.
I ran numerous tests and learned a lot along the way. I understand what I read and the comments I recieved much differently now than I did before.
I posted the results of my numerous tests here: http://philipbloom.net/forum/threads/gh2-hacks-noise.1814/
Thanks All!
Hello Everyone!
I have done a lot of testing in the past and have come to some conclusions and have many more questions as a result, and I'd like to cover some of them here.
First of all, I could find no evidence of the "ISO Bug" with my GH2. I tried everything, but got consistent results regardless of how I set the ISO.
I get noise at ISO 160. I think it's distracting and for high contrast dramatic scenes, it's unacceptable.
I purchased a nice 1/2" C-Mount lens for it's incredible low light capability, but I have to use it in ETC Mode. BTW it's one of the nicest handling lenses that I use. It is Parfocal and unlike my Nikon Prime lens, it is smooth when rack focusing in each direction without slop.
ETC Mode generates way bad noise, which renders my low light advantage of the C-Mount lens Useless.
So I can use the C-Mount lens in well lit situation, but not for the reason I purchased it. If I had the time to experiment with a GH2 before I purchased it, I probably would have purchased a more expensive option.
My question to everyone is: Do you think that Panasonic a) can fix this with a firmware update b) will they fix it if they can (with the GH3 coming out ??) ?
Is there a hack that addresses the noise problem in ETC?
Thanks in advance!
Could I ask some of you experimenters with comparable lens focal lengths but different mounts to try this at lower ISO ratings? -with image grabs showing the same content, too? @balazer 3200 iso - as much as I see your point - doesn't really make up part of my world. (also, I really thought this ETC comparison had been put to bed long ago..)
I baught the GH2 for ETC also. Cause my GH1 made eveything else good enough. The noise problem in ETC-Mode let me use it in good light situations only. But fortunately @ almost any daylight sport situations where i need fast pannings i do have good light. And with the1:1 crop the rolling shutter effect is greatly minimized.
I have tried a very good teleconverter (Minolta S-300) and it doesn't only loose light, but produces additional CA too. Most of them do.
The noise reduction at full frame is some kind of "smearing" of noise by scaling down to HD from 14 mpx, while ETC shows the true noise, which is a per pixel noise. It has a different look and good noise reducers can handle it very well. I don't consider the loss as much as a converter has.
Isn't that the same situation as with optical teleconverters where 2x tele give you 2 stops loss?
I'm wondering what's the difference in terms of noise between electronic teleconverter technology and real optical add-on lens? If I put on a 2.5x extender I guess it will give about the same amount of light loss as with decreasing the active sensor surface. But still I think that a full sensor will be less prone to intrusive noise than just a fraction of it.
There is a variety of cheap teleconverters on ebay.
So, anyone has experience with an optical teleconverter on his GH2? How does it compare to ETC?
